heater problem
Old Nov 9, 2014 | 07:57 AM
bigrx's Avatar
bigrx
Default heater problem
Hello, new here, I have 2001 rx300. My problem is that I only get heat if I turn the temp to hot. Is this something that I can fix. Any help would be great. Thanks.
Old Nov 9, 2014 | 01:34 PM
bigrx's Avatar
bigrx
I have gone through all the posts, and nobody seems to have had this problem. I was hoping one of the gurus on here would be able give a solution. Help.
Old Nov 9, 2014 | 02:26 PM
hypervish's Avatar
hypervish
Welcome to Club Lexus!
I'd check the operation of the air-mix servo.
Old Nov 14, 2014 | 05:11 PM
bigrx's Avatar
bigrx
Ok, so I took out the glovebox and worked the temp control from hot then down to 85, and I can hear the flap open to the heater and when I turn to 85, it closes again. It sounds like it is moving hard. Now my question is, where is that flap that modulates the air flow from the heater box. Also, the air flow is a bit less once the flow from the heater comes through and yes it is hot. Felt the tubes coming in and they are hot. Is this something I can do, I have worked on many cars so that is not a problem. Thanks for any help.
Old Nov 14, 2014 | 06:03 PM
salimshah's Avatar
salimshah
25 Year Member
You have a mode and mix servos. They work in unison through the Auto climate control.
The mix servo controls heat/cold functions of the heat-exchanger unit.
The mode servo then helps redirect the conditioned air.
When you set to heat (temp above ambient) the mode servo redirects the air to feet level.
You can byepass the Auto by disengaging it and manually control the mode through the mode ****.
Also do check the coolant level through the radiator pressure cap with engine cold. Lexus is finicky about coolant level and heat.
Salim
halac
Feb 15, 2013 03:30 PM
aeropartz
Dec 22, 2009 02:12 AM
MxChase
IS - 1st Gen (2001-2005)
May 2, 2007 06:05 PM
Tag129
Oct 4, 2005 11:47 PM
Baby ///M3
Dec 20, 2004 08:34 PM
