Old Dec 15, 2014, 04:42 PM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: Exterior Guides
Print Wikipost
RX300: DIY door lock actuator fix write-up
Old Apr 6, 2012 | 05:19 PM
  #61
Monkeyman6's Avatar
Monkeyman6
My guess is you have a rod or rods still unhooked.
Old May 24, 2012 | 07:26 PM
  #62
EnzoRX's Avatar
EnzoRX
Thank you 2002RX300 for posting up this RX300 fix.
My passenger side front door lock died on me. I will add some pix to illustrate the passenger side of things.
After removing the door panel you will find yourself looking at the following:
Attached Thumbnails RX300: DIY door lock actuator fix write-up-2001-lexus-rx300-door-lock-actuator-009.jpg   RX300: DIY door lock actuator fix write-up-2001-lexus-rx300-door-lock-actuator-010.jpg   RX300: DIY door lock actuator fix write-up-2001-lexus-rx300-door-lock-actuator-011.jpg   RX300: DIY door lock actuator fix write-up-2001-lexus-rx300-door-lock-actuator-012.jpg   RX300: DIY door lock actuator fix write-up-2001-lexus-rx300-door-lock-actuator-013.jpg
Old May 24, 2012 | 07:29 PM
  #63
EnzoRX's Avatar
EnzoRX
Here is a picture of the top right hand corner of where the rods join the passenger door handle and door lock actuator. I think the yellow plastic bracket is for the door handle and the orange one is for the door lock actuator.
Attached Thumbnails RX300: DIY door lock actuator fix write-up-2001-lexus-rx300-door-lock-actuator-024.jpg   RX300: DIY door lock actuator fix write-up-2001-lexus-rx300-door-lock-actuator-025.jpg
Old May 24, 2012 | 07:31 PM
  #64
EnzoRX's Avatar
EnzoRX
The door lock actuator for the passenger side
Attached Thumbnails RX300: DIY door lock actuator fix write-up-2001-lexus-rx300-door-lock-actuator-029.jpg
Old May 24, 2012 | 07:32 PM
  #65
EnzoRX's Avatar
EnzoRX
The actual door lock motor (this is my dead motor)
Attached Thumbnails RX300: DIY door lock actuator fix write-up-2001-lexus-rx300-door-lock-actuator-030.jpg   RX300: DIY door lock actuator fix write-up-2001-lexus-rx300-door-lock-actuator-033.jpg
Old May 24, 2012 | 07:35 PM
  #66
EnzoRX's Avatar
EnzoRX
After I had experience with ripping out the passenger side, I did the drivers side just for fun. Here is a shot of the drivers side door lock actuator still attached to the drivers door pull handle.
Attached Thumbnails RX300: DIY door lock actuator fix write-up-2001-lexus-rx300-door-lock-actuator-057.jpg
Old May 24, 2012 | 07:36 PM
  #67
EnzoRX's Avatar
EnzoRX
Another picture
Attached Thumbnails RX300: DIY door lock actuator fix write-up-2001-lexus-rx300-door-lock-actuator-058.jpg
Old May 24, 2012 | 07:38 PM
  #68
EnzoRX's Avatar
EnzoRX
The following are the four screws you need to remove:
Screws #1 and #2
Attached Thumbnails RX300: DIY door lock actuator fix write-up-2001-lexus-rx300-door-lock-actuator-059.jpg
Old May 24, 2012 | 07:39 PM
  #69
EnzoRX's Avatar
EnzoRX
Screw #3 is here:
Attached Thumbnails RX300: DIY door lock actuator fix write-up-2001-lexus-rx300-door-lock-actuator-060.jpg
Old May 24, 2012 | 07:40 PM
  #70
EnzoRX's Avatar
EnzoRX
Screw #4 is here:
Attached Thumbnails RX300: DIY door lock actuator fix write-up-2001-lexus-rx300-door-lock-actuator-061.jpg   RX300: DIY door lock actuator fix write-up-2001-lexus-rx300-door-lock-actuator-062.jpg
Old May 24, 2012 | 07:43 PM
  #71
EnzoRX's Avatar
EnzoRX
Here are some pix of where the tongue and groove and the round ball joint area looks like (you will know what I am talking about once you carefully take it apart and see where the parts all line up and fit):
Attached Thumbnails RX300: DIY door lock actuator fix write-up-2001-lexus-rx300-door-lock-actuator-063.jpg   RX300: DIY door lock actuator fix write-up-2001-lexus-rx300-door-lock-actuator-064.jpg   RX300: DIY door lock actuator fix write-up-2001-lexus-rx300-door-lock-actuator-065.jpg   RX300: DIY door lock actuator fix write-up-2001-lexus-rx300-door-lock-actuator-066.jpg   RX300: DIY door lock actuator fix write-up-2001-lexus-rx300-door-lock-actuator-067.jpg
Old May 24, 2012 | 07:46 PM
  #72
EnzoRX's Avatar
EnzoRX
Hope these additional pix further helps those who are contemplating doing the door lock actuator fix. I will be changing out my rear doors at a later date. I will also post pix once I get around to fixing the rear doors.
Good luck everyone!
Old May 25, 2012 | 06:59 AM
  #73
yngwie5290's Avatar
yngwie5290
Nice pics.
Old Jun 4, 2012 | 01:17 PM
  #74
RockthisNj's Avatar
RockthisNj
Lightbulb First lexus owner and figuring things out as i go along
i was able to fix my actuator in 45 mins and for $90 by buying an oem part on ebay. It was actually pretty easy to do. Just had to be patient and look at what your doing and see how everything works. It was actually trying to find help and understanding what to do that made me not want to try, but when the dealer said $600 ... It was worth the shot. I see alot of threads for things i wanted to do and some are helpful but alot make it sound way worse then it is. I changed all my bumper lights to clear and trying to figure out how to do the rear ones was a nightmare until i just got in and started unscrewing things. All i had to do was take off those mudflap type things and 2 bumper screws and just wedge my hand in there. The fronts were not too bad....everyone saying to take off the wheels...no way, driver side easy just pull back and unbolt and the passenger side was a pain but just need a small wrench. now if anyone can help me with an easy way to remove the entire headlight casing, that would be helpful...thank you very much
Attached Thumbnails RX300: DIY door lock actuator fix write-up-lexus.jpeg
Old Jun 9, 2012 | 03:02 PM
  #75
lexrally's Avatar
lexrally
I jut finished fixing my passenger side rear door, and driver side front door. Felt I had to, having both doors not working was just not acceptable. Shop wanted $550 per door. Took me 6 hours total. Took my time, and made sure I knew how to put everything back the way I took it out.
The biggest hassle for me was cutting the actuator case. I started with using a box cutter, but was not making good progress. So I went to Lowes and bought a Dremel for $50, and used that. It worked fine, I just tried not to cut all the way thru with it. Using the groove I created wtih the Dremel, I then used the box cutter to finish cutting thru, that way I still had the surfaces contacting each other when I put the side back together. Used super glue to keep it together after replacing the motor.
The connecting rods at first were making me nervous when I was trying to figure out how to unclip and put them back. It was not easy for me to see in there.
The rear door was definitely easier than the front door.
And all the while I was doing the job, I was cussing at Lexus for putting such a !@#$% little tyco motor inside the door for such an important function. Are you kidding me???
Thanks to this forum, and this wonderful DIY for giving me the courage and guidance to get this fixed!!!!
