HELP! Code 1354 VVT system fault
Old Dec 24, 2010 | 08:37 PM
Barry1022's Avatar
Barry1022
Default HELP! Code 1354 VVT system fault
OK, I got this code 1354, the engine was running very rough. Then it gave codes 0300, 0302, 0304 and 0306. I know all 3 ignition coils didn't go out at the same time so I figure the timing fault is causing the 3 cylinders to misfire. How do you fix this variable valve timing system fault? Is is something in the computer? I'm thinking this may be causing the misfires, but please correct me if I'm wrong.
Thanks,
Barry
Old Dec 25, 2010 | 11:08 AM
Barryst's Avatar
Barryst
Could possibly be your front Oil Control Valve.
There is a illustration here:
https://www.clublexus.com/forums/rx-...304-p0306.html
Try the search function, It can help sometimes to gather more info. There's a lot here.
-Welcome to the forum!
Old Dec 27, 2010 | 04:56 PM
Barry1022's Avatar
Barry1022
I replaced the Camshaft Position Sensor and so far so good......runs like it used to! That makes sense because I was getting misfires on that bank. Thanks!!
Old Dec 28, 2010 | 05:52 PM
Barry1022's Avatar
Barry1022
UPDATE.....it started idling rough so I scanned it again and got the same 1354 code! It seems to run good until I have to stop at a light or something. I'm going to pull the OCV next, clean or replace it then see if that does the trick. I thought I had it fixed......oh well, anymore suggestions?
Old Jan 2, 2011 | 02:52 PM
Barry1022's Avatar
Barry1022
Default testing an OCV
I read in another thread on how to check an OCV. The ohms settled in at around 7.5 and when I energized the OCV, the cylinder moved back and forth. Can anyone tell me if this is a sure fire way of testing because I still get the same codes, 1354, 302, 304, and 306. You think I should replace it anyway? Whats another $100 at this point? LOL
Thanks guys.........
Old Feb 13, 2011 | 06:26 PM
bachlauter's Avatar
bachlauter
Default What was your solution?
Barry..
I have an es300 throwing me the same exact codes..
What was your ultimate solution?
Old Feb 13, 2011 | 06:40 PM
tomstep2's Avatar
tomstep2
I just dealt with the same situation. Turned out that my VVT Solenoid was malfunctioning. I had it replaced and runs like a dream again. Hope this helps!
Old Feb 14, 2011 | 11:55 AM
bachlauter's Avatar
bachlauter
Where is the vvt solenoid located? I checked for sludge and there is none. I checked the ocv and it's clean as a whistle. Once I clear the code, the car drives perfectly. As soon as the MIL lights up, it starts running really rough and misfiring. I'm sorta confused because I feel like if I have this vvt problem, wouldn't misfiring occur all the time? I haven't ruled out the ECM.
Old Feb 14, 2011 | 12:19 PM
thomas1's Avatar
thomas1
sounds like the OCV valve is intermitant....replace it and also check the ocv valve filter.
Old Feb 14, 2011 | 02:19 PM
Barry1022's Avatar
Barry1022
Default my solution
If anyone is interested, I first replaced the cam sensor, that wasn't the problem. But, as soon as I replaced the Oil Control Valve, it hasn't missed a lick since. My old OCV was clean and when energized it did as it was supposed to but since it was intermittent problem I guess I tested it at a good time. The only thing I could not do was check the OCV filter. I'm not sure where that is located. Hope this helps! Thanks to everyone that offered advice.
gotkiet
12
Feb 25, 2020 08:47 AM
jckol
Dec 7, 2016 06:08 PM
Stevius
Dec 27, 2014 12:19 PM
02msmg3
Dec 13, 2010 11:47 AM
