Lubrication points?
Old Nov 7, 2009 | 07:09 AM
fastnoypi's Avatar
fastnoypi
Default Lubrication points?
I received a flyer from the dealership for an oil change and lubricant special.
An oil change is easy to do, what exactly are they lubricating and where are the lubricant points on our cars? Is there a list available?
I found this general link on autopedia, i assume these might be some of the lubrication points.
http://www.automedia.com/Greasing_Parts/ccr20050601gg/1
Old Nov 7, 2009 | 05:30 PM
bob2200's Avatar
bob2200
Some of the new palacial Lexus dealerships have windows from the waiting room to the service bays. I don't think you will find mechanics doing any lubing as part of an oil change at most Lexus dealerships (my opinion), but maybe some do.
I think the "lube" term is a hold-over to olden days when all cars had grease fittings that needed regular lubing.
The lube points shown in your hyperlink are good ideas, but I just don't think most dealerships regularly do this kind of stuff. At least not for the $40 and $50 oil changes.
Old Nov 8, 2009 | 12:24 AM
code58's Avatar
code58
I agree with Bob- Maybe some of them do that stuff, but I would be amazed if they did. I have never seen any who have. When I was a teen ager working in a dealership in the small town I grew up in I did lube work and did that kind of lubing, but I think they would look at you cross eyed and stutter if you asked them if they lubed all those points.
Old Nov 8, 2009 | 02:20 AM
artbuc's Avatar
artbuc
I lube all of the points shown on an as needed basis. It makes a big difference (at least I think so) especially door hinges, door locks and antenna mast.
Old Nov 8, 2009 | 02:37 PM
code58's Avatar
code58
I'm proud of ya Art. We're holding a job open for you down at Joe's Lube and Bowl. Seriously, that is an excellent idea. I have seen the rollers (on hinges that use roller check-stops) frozen solid and the roller worn flat on 1 side. Doesn't take long to do that stuff and definitely pays off. I just don't think most lube shops do it. I saw posted on 1 of the Ford truck sites a picture of an air cleaner element installed in a Pontiac Sunbird by 1 of the quick lube places. They had taken the new element, folded it like a taco and STUFFED it in the box. The driver (co. car) wasn't aware until a few thousand miles later when he took the top off to check something. He was HOT! Wonder why I do all my own work?
Old Nov 8, 2009 | 04:53 PM
trhs75's Avatar
trhs75
Do you use white lithium grease on the hinges or just what?
Old Nov 8, 2009 | 09:53 PM
code58's Avatar
code58
As for me, that is generally what I use. Depends on how the hinge is made. I have several different types of lubricant in spray cans. I prefer the lithium in the spray can just because it's easier to use. It's a little tough to apply the WL with a brush neatly. I don't particularly like WD-40, but if the hinge is getting a little dry and creaky, I will use it to try and get it in on the pin.
diitto
NX - 1st Gen (2015-2021)
Oct 2, 2016 07:02 PM
evident
Nov 5, 2015 08:30 PM
PHXF
IS F (2008-2014)
30
Oct 10, 2009 02:11 PM
tieu
Canada
12
Oct 16, 2008 12:09 AM
HowieNJ
Maintenance
Oct 4, 2002 08:27 AM
