Obdii Code 0171
Old Jul 16, 2007 | 11:37 AM
gazi001's Avatar
gazi001
Default Obdii Code 0171
I have check engine sign on my 2000 RX 300 for two weeks. I scaned with Snapon advance scanner and it says code 0171 system too lean Bank # 1.
I read the explanations of this code in the book, it says MAF sensor, Catalyst, Oxygen sensor. One week before I clear the code and the check engine sign gone but came back after a week. Now I change the oxygen sensor on next to engine on top but one day later check engine sign came back. What should I do. Please help me about this.
Old Jul 16, 2007 | 01:33 PM
Meetya's Avatar
Meetya
What are the pending codes? P0171 cannot be by itself. By the way, for 2000 RX P0171 means the System is Lean (either Bank 1 or Bank 2).
You changed A/F before catalyst on Bank 2. Might as well check the one on Bank 1.
But first get pending codes, I bet they are gonna be one or more of the following:
P1130, P1133, P1135 (Bank 1 A/F Sensor)
P1150, P1153, P1155 (Bank 2 A/F Sensor)
P0100, P0101 (MAF Sensor)
You also might get P0125
Old Jul 16, 2007 | 02:59 PM
Lexmex's Avatar
Lexmex
Did you clean the MAF sensor?
Old Jul 22, 2007 | 09:06 PM
gazi001's Avatar
gazi001
I have only one code 0171 nothing else. I also cleaned the maf sensor and changed the A/F sensor on bank 1 on the bottom of the engine. But I have the CEL again and the obd code 0171 only.
Old Jul 22, 2007 | 09:44 PM
Meetya's Avatar
Meetya
Check again, P0171 never comes alone. You have an OBD-II scanner? If not ask for PENDING codes.
Old Jul 22, 2007 | 10:17 PM
zombie's Avatar
zombie
my 99 came with P0171 alone. check if you have any exhaust leaks, because that was my problem.
Old Aug 20, 2007 | 08:12 PM
BronzeRex's Avatar
BronzeRex
clean the maf sensor and check for leaks. i had the same problem last year and i replaced the maf sensor, then two months ago i got P0174
System Too Lean (A/F Lean Malfunction, Bank 2) code i erased it an then the P0171 came back. so i also replaced the O2 sensor after the cat and havent gotten any more codes
Old Aug 27, 2007 | 01:56 AM
Christian8's Avatar
Christian8
clean your MAF sensor with throttle body cleaner, clean the seals, reinstall, check your accordion bend for cracks(part of the exhaust that bends by the driveshaft[if you have awd]), disconnect the negative terminal for about a minute and drive 100 miles, the time it takes for the computer to register anything. See if that helps. If that doesn't then you could have a faulty O2 sensor.
Old Sep 10, 2007 | 10:43 AM
gazi001's Avatar
gazi001
I cleaned MAF sensor but didnot work. I bought a new MAF sensor from the dealer and installed then the CEL gone.
Old Sep 10, 2007 | 11:09 AM
DJ TANTRA's Avatar
DJ TANTRA
If it comes back..
Like one of the members said earlier..
Jack ur car up...
Start IT
And check if you have any exhaust leaks...U might need a new gasket..
It's not a major repair if u do need one..
Gasket costs like 10 bux..and install is a DIY..but a shop wud do it too
Old Sep 10, 2007 | 12:25 PM
zombie's Avatar
zombie
i buy my maf from autozone because its only $80 and comes with a 1 year warranty.
i even told them i tried cleaning my sensor and broke it. they still let me exchange it for a new one for free.
Old Sep 10, 2007 | 08:10 PM
ehizon's Avatar
ehizon
hi -
this might help you. i have an rx330 and i got the same error code. read my posts.
https://www.clublexus.com/forums/sho...d.php?t=295934
Gioperrone
16
Mar 7, 2021 06:29 PM
nid
Nov 6, 2016 06:05 AM
qwerty04
Jan 29, 2012 11:32 AM
jerryhbr
Apr 10, 2008 12:47 PM
Deceptik1
Aug 14, 2002 12:50 PM
