Intermittent Starting Isssue
I have a 99 RX300 with about 250,000 miles on it. My wife recently took the car on a trip longer than I typically like to drive it. The drive was about 90 miles each way and goes from sea level, to 6600 ft,, and back down to sea level. I took the car shortly after she returned and noticed it didn't start the first time. I always think "maybe I just didn't hold the key long enough" and so I attempted to start the car again. It started up and drove fine.
Today it was stumbling a bit when heading into town and then later in the day it didn't start again. It took a few tries but I realized that when I pumped the gas a bit on startup it would idle and I could drive home. I'm not getting any codes and the only thing I notice is that there seems to be a bumping sound that seems like it's coming from around where the air filter/mass flow sensor is located.
The fact that it requires me to pump the gas to start it up, should I direct my efforts toward the fuel filter/pump/pressure? Because I'm not getting any codes I'm a bit confused where to start.
Thanks
Next time just hold the pedal 1/4 or 1/3 down and try to start. If it starts and when you let off the pedal it stumbles then the culprit is most likely the IACV. Do a search on IACV and you will find lot of detailed information.
You may also like to look at the air cleaner and MAF [use appropriate cleaner for RX MAF]. You will find plenty to information on cleaning the MAF as well.
You can have the pressure on fuel line tested, but you would need specifications as well as test set up.
I would not suggest start changing out things on hunch. Instead gather evidence.
Salim
PS: Failing to hold idle/or sustain idle is slightly different from failing to start.
Start with the air and then move to gasoline afterwards. Don't be too tempted to clean the throttle body just yet. Stay on the IACV section to begin with. Make sure the plug can move freely and the passages are clear.
Salim
I also noticed that the throttle body was attached to the intake with only two of the three bolts and one of the two was fairly loose. This caused a gap that allowed air to enter the intake post MAF and IACV sensors.
I added a new bolt, tightened all three, and reassembled everything. Thankfully the engine started up without the need to depress the pedal. I'm not sure if the minimal amount of attention I gave to the IACV was the reason the issue went away or whether it was due to the intake to throttle body gap. In any case, I'm a happy camper to have a properly running vehicle again.
Thank you Salim as always for your assistance.
