Radio
Old Sep 17, 2023 | 07:22 AM
davidsboss's Avatar
davidsboss
6th Gear
Default Radio
Hello, I have a 99 Rx 300 the problem I’m having is the radio, only the passenger speakers work. any help would be appreciated, Thanks.
Old Sep 17, 2023 | 03:01 PM
salimshah's Avatar
salimshah
25 Year Member
Please play around with balance and try changing source Radio/CD. Also pay attention to tweeters to see if high frequency sounds on the left are working.
Once you observe no change, you may have to open up the driver door panel and verify the speaker is still good. Look for dry rot and check ohmage.
Next would be to check for break in wire ... specially around the door hinge as that gets flexed with every door operation.
If you get past those, the next would be the AMP or the headunit. The headhunt provides pre-amp out and you have to inject audio level signal to see if the amp is working.
If the amp works then it is the head unit.
Keep in mind first gen came with Pioneer or Nakamichi. So when you look for replacement, make sure you get the right kind as they are not interchangeable.
Salim
willameena
Jun 6, 2023 10:59 AM
Catman37
May 2, 2016 05:11 AM
Gsnuggs
Sep 16, 2012 12:07 PM
rcodey
Apr 28, 2005 01:59 PM
