Rough start
Old Oct 5, 2013 | 08:19 AM
kyle0k's Avatar
kyle0k
Default Rough start
So yesterday out of no where my 2006 IS350 with 120k miles starting getting a very rough start. I've had it since 60k miles and its been great.
What I mean is that after pressing the start button, it turns over and it tries to start for a good coupe seconds. With no input from me, it might not even start on the first try. If I do the old trick of giving a bit of gas as a press the start, it will always start within 2 seconds (still longer than normal). This started out of nowhere, and wasn't a gradual thing. It doesn't matter if the engines hot/cold. The car itself drives fine.
I also thought I MIGHT have smelt a slight odor of gasoline, but that could have been my imagination.
What can this be?
Old Oct 5, 2013 | 07:43 PM
Kappy550's Avatar
Kappy550
If you're having to give it gas to start, it sounds like you may be losing your fuel pump. From what I'm told its not too hard to replace yourself on these cars. Good luck!
Old Oct 6, 2013 | 07:40 AM
kyle0k's Avatar
kyle0k
Any way to confirm its the fuel pump?
Old Oct 6, 2013 | 12:43 PM
istundra's Avatar
istundra
just going to ask... how old is your battery? Maybe time for replacement with high cranking amps?
Old Oct 7, 2013 | 10:41 AM
kyle0k's Avatar
kyle0k
My battery is only about 2 years old.
HOWEVER, I am starting to think its the battery. I checked the battery while the car was off, with a voltmeter. It metered at 10.35 which is below the 12v its supposed to be.
So either my battery is prematurely dead or the alternator is going? In the last month or two, most of the trips have been <10 minutes, so I'm hopeful its not the alternator and it just didnt have a chance to recharge the battery.
How can I test if its the battery or alternator?
Old Oct 7, 2013 | 11:48 AM
See5's Avatar
See5
I think it is the battery
My "exide" battery died after one year exactly ( 7 days after warranty finishes ! good marketing there lol)
try to start it with the high beam on, if it doesn't then you need a new battery.
good luck
ecassaro19
May 15, 2018 01:22 PM
MJA1951
Apr 18, 2018 06:14 PM
FWizard
IS F (2008-2014)
Mar 26, 2017 09:13 PM
La Lex
Mar 11, 2011 07:32 AM
Im2gq4u
Sep 9, 2008 04:14 PM
