Engine knock
Old Aug 2, 2023 | 01:27 PM
rmk9785e's Avatar
rmk9785e
Default Engine knock
Recently my vehicle has developed a popcorn popping sound when trying to accelerate. What could be causing it and how can it be fixed?
Old Aug 2, 2023 | 07:05 PM
salimshah's Avatar
salimshah
25 Year Member
RX is equipped with engine knock sensors and it adjusts timing to compensate. If it cannot then it will throw a CEL along with a code.
There can be many reasons to hear a knocking sound and the best way to diagnose is to go to a competent mechanic. Usually they diagnose for free or for a fee which can be used towards the repairs.
Salim
Old Aug 7, 2023 | 08:35 AM
rmk9785e's Avatar
rmk9785e
Default P0330 Knock Sensor 2 malfunction
Salim
This is what the tech found. He said: “Your car is running lean which means it’s taking in more air than it should and it’s compensating by using a ton of fuel.”
What's the Lexus part number for the knock sensors? Would it make sense to replace both sensors when the engine cover is opened?
Old Aug 7, 2023 | 09:39 PM
salimshah's Avatar
salimshah
25 Year Member
Please look up the DIY sticky thread.
Other than the actual replacement, there are two other test methods.
Actual replacement is pretty intensive 6-8hrs of labor time. Top end has to come off and you would be needing various gaskets.
OEM sensors are not cheap and it is recommended to replace the wire too.
You will need to take the vin to the dealer to get the right sensor.
Salim
Old Aug 8, 2023 | 01:07 PM
rmk9785e's Avatar
rmk9785e
Thank you. This may sound dumb but how do I find the relevant sticky since there are so many?
Old Aug 8, 2023 | 01:29 PM
maxSteel's Avatar
maxSteel
Open https://www.clublexus.com/forums/rx-...x300-diys.html
At the top, "search this thread" for "knock"
Gets you to https://www.clublexus.com/forums/rx-...ml#post5279318
t100toyota
GX - 1st Gen (2003-2009)
Oct 21, 2021 01:07 PM
KuroYuki
Jun 19, 2020 02:02 PM
goldenrod
Mar 15, 2018 04:54 PM
LexedUp
Jun 16, 2011 04:00 PM
Hacc
Nov 18, 2008 10:37 PM
