Another Transmission Question
Old Aug 11, 2023 | 11:50 AM
JAB's Avatar
JAB
Default Another Transmission Question
Hi: 2002 RX300; second owner; currently 250K miles. Reasonably well maintained by previous owner. Transmission works flawlessly in forward gear, and in reverse until there is a noticeable slope at which point it shudders and slips. What is the likely explanation? Possible to repair in place? Had a 1999 RX300 in which the transmission failed at 120K; not interested in replacing the transmission in a 22 year old car with 250K. Thanks.
Old Aug 11, 2023 | 09:15 PM
salimshah's Avatar
salimshah
25 Year Member
Don't expect much help from the internet. Realistically, you would get the proper advice/option from a transmission shop.
Salim
Old Aug 11, 2023 | 09:28 PM
maxSteel's Avatar
maxSteel
Assuming up mean you are driving up a "noticeable slope" in reverse then it is under increased load and maybe that causes a slip.
But another effect of the slope is on the fluid, it would pool towards the front of the pan and maybe the flow is affected.
Is the level right, quality good, filter ok?
Old Aug 12, 2023 | 08:56 AM
JAB's Avatar
JAB
MaxSteel: Yes to all your questions.
Old Aug 12, 2023 | 11:49 AM
salimshah's Avatar
salimshah
25 Year Member
The transmission itself is pretty complex component. As an owner one can typically do level checks and condition of fluid + filter. Inside there are hydraulic paths which are operated by the ECU and drive gear selector. Any issue with the solenoid(s) and or passage(s) + condition of the bands + clutches is best determined by transmission expert.
My concern is with that much milage on the clock is it worth paying an expert for evaluation? But then again they change a solenoid to put you back on the road.
Salim
Old Aug 15, 2023 | 01:36 AM
Australian's Avatar
Australian
Do a drain change filter and refill with new fluid. Add some more magnets if you got them and see if you can notice improvement. I would service before anything as you have a first sign so don't ignore it or drive it till it stops like everyone else. Not many take first signs seriously enough you might fix it with maintenance rather than rebuild.
Sounds
Hybrid Technology
Jun 13, 2023 04:50 AM
debor300
GS - 1st Gen (1993-1997)
Sep 21, 2022 07:06 AM
ZishanM
Nov 3, 2011 02:11 PM
MrBruin09
Jan 10, 2011 06:00 AM
rx300ownde
Jan 27, 2008 05:22 PM
