Replacement brake lines
Old Aug 15, 2019 | 06:32 PM
tekjunke's Avatar
tekjunke
Default Replacement brake lines
I’ve decided that I’m going remove my calipers and have them professionally painted. I’ve tackled much larger projects in the past but this will be my first foray into actually removing calipers. I’ve ordered a full set of caliper hardware for all 4 corners, and I’d also like to replace the brake lines. The Toms lines seem awful pricey for a daily driver that will never see the track.
Has anyone used other lines besides Toms? Recommendations welcome.
Thanks
Old Aug 15, 2019 | 06:54 PM
flowrider's Avatar
flowrider
Veteran: Air Force
Modern Brake lines (Lexus lins) are awesome lines. IMHO, no reason to replace them.
Lou
Old Aug 15, 2019 | 07:12 PM
tekjunke's Avatar
tekjunke
Thanks Lou. Again I’m still researching the best process here... but I was under the impression that the existing lines should be replaced with new factory ones at a minimum. I was planning on clamping the existing lines (to retain the fluid) and cutting them while leaving the banjo bolt attached to the caliper during the painting process for a perfect mask of the the connection area. Is there a better way?
Old Aug 15, 2019 | 07:37 PM
Mingofish's Avatar
Mingofish
Cutting them ??!!
If you’re gonna remove the caliper, just remove the lines completely and let the caliper drain out all the way.
Just bled fluid properly post installation.
Old Aug 15, 2019 | 08:39 PM
flowrider's Avatar
flowrider
Veteran: Air Force
This^^^^
Lou
trhs75
RX - 1st Gen (1999-2003)
May 16, 2018 06:34 PM
ZaxF
IS F (2008-2014)
Mar 27, 2017 12:48 PM
Defratos
IS F (2008-2014)
14
May 18, 2013 01:40 AM
Kalogerus
Jan 26, 2012 10:14 AM
Rockero28
Suspension and Brakes
Jul 14, 2002 10:42 PM
