IS200t Downpipe
Old Jul 23, 2018 | 04:23 PM
  #121
Sheddy's Avatar
Sheddy
Originally Posted by Clrex
i am little confuse. I thought downpipe installation is straight forward? According to Tony, am i suppose to change replace a casket for a catless DP?
The original gaskets should still be good. You need to get a 90 degree spacer on the 2nd O2 sensor bank and you should be fine.
Old Jul 23, 2018 | 05:16 PM
  #122
Clrex's Avatar
Clrex
Yes that what my mechanic trying to fix. Just left a bad taste from the whole experience with TTI. Thinking of forgoing the whole catless DP and get a catted one instead. Hows your experience with PPE catted DP and the support from them?
Old Jul 23, 2018 | 06:27 PM
  #123
Sheddy's Avatar
Sheddy
I've never had an issue with TTI, so that's a first. PPE is awesome! They make a very good product and are highly recommended in the Lexus community.
Old Jul 23, 2018 | 10:06 PM
  #124
tnilc's Avatar
tnilc
I have a PPE de-catted downpipe and they were more than helpful in helping me and even sent me some spacers to try. In the end, I figured it out on my own and used spacers I purchased.
Old Jul 24, 2018 | 02:54 AM
  #125
pnoygil's Avatar
pnoygil
When removing the stock downpipe and installing the new downpipe is it from the top or bottom of the car! Thanks
Old Jul 24, 2018 | 07:15 AM
  #126
Sheddy's Avatar
Sheddy
Both actually. The upper section of the turbo (connects to charge-pipe) is removeable to allow access to the turbo. Once you remove that section you will be able to remove the heat sheild from the top and then have access to the downpipe bolts.
Old Jul 24, 2018 | 12:38 PM
  #127
pnoygil's Avatar
pnoygil
Thanks. Yes I understand that u have to take apart the top part but im asking if the downpipe can be remove from top or bottom of the car...
Old Jul 24, 2018 | 12:47 PM
  #128
Sheddy's Avatar
Sheddy
It is easier from the bottom of the engine bay.
Old Jul 24, 2018 | 04:22 PM
  #129
pnoygil's Avatar
pnoygil
thank you... im just waiting my estimate from TTI. I will be installing in my garage by myself...
anyone have used one let me know. Ship to Hawaii zip 96797
Old Sep 2, 2018 | 09:55 AM
  #130
tnilc's Avatar
tnilc
Sad...my CEL came back. But I'm thinking it's because I put 89 octane instead of 91? I've always done 91, even though I can take 87. I'm hoping that's the case as the CEL came on a minute after I pumped gas. Now I'm just trying to burn through this half tank and refuel with 91.
Old Sep 2, 2018 | 10:07 AM
  #131
pnoygil's Avatar
pnoygil
You should follow the manufacture spec u suppose to up not downgrade, our car has high compression with turbo and it tune for 91 octain and up... you have Cel not because you have downpipe, it could be the gas your using and it making your engine to knock or pre ignition which is really bad...
Old Sep 2, 2018 | 10:17 AM
  #132
tnilc's Avatar
tnilc
Manufacturer spec is 87.
Old Sep 2, 2018 | 10:35 AM
  #133
Flash5's Avatar
Flash5
Manufacturer spec is definitely 91. Idk where you’re getting 87 from.
Old Sep 2, 2018 | 10:46 AM
  #134
tnilc's Avatar
tnilc
Ah **** maybe I misunderstood my salesman, I have an RC300 and he said 87 is Ok, car doesn't have any warning stickers saying use premium fuel only like my IS did.
Old Sep 2, 2018 | 10:52 AM
  #135
Flash5's Avatar
Flash5
If it makes you feel better my salesman and sales manager tried to tell me I could put 87 in my car and I was like you guys are garbage.
