IS200t Downpipe
Old Apr 1, 2020 | 04:41 PM
  #211
flowrider's Avatar
flowrider
Veteran: Air Force
^^^^You need to get the code for any kind of analysis. You can go to most auto supply stores and they can read the code for you. Also, you may want to buy an OBD code reader for yourself.
Lou
Old Apr 1, 2020 | 08:37 PM
  #212
tnilc's Avatar
tnilc
Lou
If it's a P0420, more than likely an issue with the O2 adapter. The downstream sensor is reading too hot which is causing the CEL.
If your adapters came with different size restrictors, you should try the smallest one and go from there.
I'm lucky to be going basically 22 months CEL free!
Old Oct 4, 2022 | 10:59 AM
  #213
Suhaib1987's Avatar
Suhaib1987
10th Gear
Originally Posted by Sheddy
No, the PPE (decatted) comes with a 90 degree O2 sensor spacer that would avoid a CEL, whereas the TTI has an O2 sensor diverter built inside of the downpipe. Now if you got the catted version then you shouldn't need an O2 sensor spacer. Sorry for the confusion.
Can you please give me the link to order it
Old Apr 8, 2023 | 12:16 PM
  #214
Doublestac's Avatar
Doublestac
Anyone running catted version? Best place to buy one? The few I found are $1500+, is that right? I've never paid more than $800 for a catted d/p.
Old Apr 8, 2023 | 12:21 PM
  #215
tnilc's Avatar
tnilc
High performance, high flow cats like Gesi are expensive. About another 600$ to the bill.
Old Apr 8, 2023 | 12:39 PM
  #216
Doublestac's Avatar
Doublestac
Brand(s) to consider?
Old Feb 19, 2024 | 02:45 PM
  #217
AlexisAlvarado's Avatar
AlexisAlvarado
1st Gear
Default Circuit Syndicate Downpipe
Originally Posted by canibeat
How are you liking the OBX downpipe? I just pulled the trigger on the Circuit Syndicate Donwpipe pictured in your screenshot.
Wanting to know how reliable that downpipe was for you any pros and cons and is it worth getting? I was able to snag a brand new one same brand for $50
Sheddy
RC - 1st Gen (2015-present)
30
Feb 24, 2022 03:27 AM
Hoovey689
Feb 18, 2020 09:17 AM
Hoovey689
Jul 12, 2019 08:42 AM
18017
Sep 3, 2016 11:59 AM
