GS480 Stick Shift For Cheap Asses!
Old Sep 29, 2016 | 04:32 PM
  #61
CRASHMONK's Avatar
CRASHMONK
Who's got an intake??
This Guy!!!
Old Sep 30, 2016 | 05:35 PM
  #62
CRASHMONK's Avatar
CRASHMONK
Tach fix is too easy. 12V through a 1k ohm resistor connected to the tach wire. And of course changing the output to 6 cylinder instead of 4.
Old Sep 30, 2016 | 08:30 PM
  #63
badblackgs's Avatar
badblackgs
ummm... not sure if it matters to you or not but i think the throttle body is backwards. not knocking whatsoever. just an observation. btw. congratulations. you've accomplished quite a feat of creativity. more pics as it progresses please. and what are you talking about changing from 4 cylinder to 6 cylinder?
Old Oct 1, 2016 | 05:28 AM
  #64
CRASHMONK's Avatar
CRASHMONK
The throttle body is upside down because there was literally no other position to mount it. If it were cable operated then it would really have sucked! The DBW seems to be dead on but i can't REALLY judge that yet being i still haven't driven it .
Thanks, I'm beyond stoked to go spank this car, but i realize i need to take my time and get it right. STILL WAITING on exhaust.
For the tach, LSX engines have a 4 cylinder tach output from the factory. In hptuners was simple as changing a cell number.
Old Oct 1, 2016 | 05:56 AM
  #65
CRASHMONK's Avatar
CRASHMONK
Old Oct 3, 2016 | 02:06 PM
  #66
bloodMoney's Avatar
bloodMoney
LMAO! Scared the baby....
Old Oct 3, 2016 | 05:20 PM
  #67
CRASHMONK's Avatar
CRASHMONK
Goofy kid, turns 1 in a few days, he will sit perfectly happy and not scared if he is on my lap in the car. I can rev the **** out of it and he isn't even phased... My 3 yr old loves daddy's new car!
Old Oct 3, 2016 | 05:33 PM
  #68
CRASHMONK's Avatar
CRASHMONK
Looking a little more tidy. Needs a serious power washing
Used a 99 Bonneville pcm box with the mounting legs cut off, mounted to a bent sheet of metal. It's still humping the alternator but better than before.
Only had to move ONE pin in the obd port, the green/ black striped wire. Ls engine talks over one serial wire.
Old Oct 4, 2016 | 04:50 PM
  #69
CRASHMONK's Avatar
CRASHMONK
Some assembly required!
Old Oct 4, 2016 | 06:09 PM
  #70
badblackgs's Avatar
badblackgs
nice exhaust setup, thats actually legit. whats the diameter though. keeping in mind thats only a 4.8 liter and only about 250ish horsepower. doesn't require too much pipe diameter. but you already have the pipe so onward.
Old Oct 4, 2016 | 06:34 PM
  #71
CRASHMONK's Avatar
CRASHMONK
Thanks my exhaust guy came through. It's no fancy mandrel bent system but the bends look fine to me. Full 2.5 inch manifold to muffler. I chose 2.5 to try and "futureproof" for whatever larger engine ends up going in later. I believe the best bang for buck later will be an entire engine swap over a cam or engine work. But hey, maybe I'll change my mind.
Old Oct 4, 2016 | 07:00 PM
  #72
badblackgs's Avatar
badblackgs
ya a friggin cammed 6.0 would be the shiznit.
Old Oct 5, 2016 | 07:34 AM
  #73
kamlung's Avatar
kamlung
thanks Monk for the updates.... sick build and glad you got the car running under it's own power...
i love the occasional 'discreet' beer in some of your pictures... gotta hydrate while we work!!! :cheers:
Old Oct 5, 2016 | 04:38 PM
  #74
CRASHMONK's Avatar
CRASHMONK
Thanks! This is actually the cleanest of my 3 engine Swaps so i appreciate it. "Hydration" is key when fixing your ride...
Old Oct 5, 2016 | 04:50 PM
  #75
CRASHMONK's Avatar
CRASHMONK
Throttle harness through firewall protected by a 1/4 in hose and a grommet.
The mufflers in my previous post were too long. Also I'm broke now. So I'll ride the stock mufflers out till they get loud. Meh
Almost there!
