IS200t tune
Old Apr 11, 2017 | 07:44 PM
  #496
Nuke's Avatar
Nuke
Originally Posted by IS200TFOWL
That's GREAT! Do you also already have the downpipe?
Yes down pipe is already in, and car is very much louder...tune is put on hold till Saturday as TTi UAE had some issue so will keep you guys posted
Old Apr 11, 2017 | 09:41 PM
  #497
PGARazor's Avatar
PGARazor
If you do any of Stage 1 or 2 make you lose warranty and is it detectable by Lexus?
Old Apr 11, 2017 | 10:06 PM
  #498
Nuke's Avatar
Nuke
Thats one of the reasons why we asked about the option of restocking the car and it is possible and the tool is now more affordable so you can do it before taking the car to the service....but in any case dealer wont look into the ROM unless there is a major issue with the car
Old Apr 12, 2017 | 05:54 AM
  #499
Sheddy's Avatar
Sheddy
Yup, with the tools you'll be able to switch to stock before taking in the car for any mechanical issues.
Old Apr 12, 2017 | 06:16 AM
  #500
PGARazor's Avatar
PGARazor
I must have missed but asking, what includes with each tune?
Noob hear and soaking all this information in.
Old Apr 12, 2017 | 06:29 AM
  #501
Sheddy's Avatar
Sheddy
What TTI and OV are offering is a reflash of the ECU. This reflash (tune) adjusts parameters such as throttle,boost, Air/Fuel ratio, timing, VVTI engagement etc. to create more power out of the engine. TTI offers a Stage 1 tune which is a safe setup for a stock motor and a Stage 2 which they recommend using for bolt on's such as a downpipe or turboback exhaust and intake.
You will get the tools needed to read and write the tune into the ECU using a windows laptop. You send them your stock tune file and they make the adjustments to make it either a stage 1 or 2, then you load it into your ECU and enjoy.
Old Apr 12, 2017 | 06:57 AM
  #502
Sheddy's Avatar
Sheddy
VORTEX style de-catted downpipe.
Smooth style de-catted downpipe
https://www.clublexus.com/forums/clu...ml#post9832815
Old Apr 12, 2017 | 07:42 AM
  #503
PGARazor's Avatar
PGARazor
thank you, very helpful.
So if I do get Stage 1 is there no need for Toms piggyback box? Looks like next move is to barrow my laptop back from my niece for a week and get Stage 1 for stock motor. Exciting times
Old Apr 12, 2017 | 08:05 AM
  #504
Sheddy's Avatar
Sheddy
Nope, i will not advise running a piggyback together with a re flash. The re flash will give you better gains
Old Apr 12, 2017 | 12:13 PM
  #505
PGARazor's Avatar
PGARazor
Figured but just wanted to confirm. Thanks
Old Apr 12, 2017 | 12:20 PM
  #506
Sheddy's Avatar
Sheddy
No problem. The ECU reflash from both companies are reversible as well.
Old Apr 12, 2017 | 10:34 PM
  #507
Tg22ar's Avatar
Tg22ar
Default Toms Power Box
Got it today from Japan. Got it in 5 days. Installed it earlier and there is a very noticeable gains throughout the entire power band. I also have an injen spt intake, invidia q300 AB, and invidia midpipe. Before installing the box it would peak and hold at 17psi, after the install. I was peaking at 21-22psi and holding at 20psi. For the price I paid, it was well worth the wait and cost. I highly recommend it. Sheddy put me onto it. Thanks bro. If you want a "stealth" tune, this is it.
Old Apr 13, 2017 | 12:23 AM
  #508
Nuke's Avatar
Nuke
Toms box is one of the best out there for this car so enjoy it
Old Apr 13, 2017 | 05:45 AM
  #509
Sheddy's Avatar
Sheddy
Great stuff man, enjoy!!
Nuke, did the down pipe throw a check engine light on the stock ECU?
Old Apr 13, 2017 | 07:20 AM
  #510
Nuke's Avatar
Nuke
nope but its fair to say that the DP am using is a smart design, the sensor sits in a small compartment that is lightly perforated which only passes little gases, this in turn makes it a permanent solution to never get a CEL light though I have to say on warm up the car is abit loud but after that its all good, don't forget i have invidia mid pipe and Q300 cat
