IS200t tune
Old Apr 18, 2021 | 01:16 PM
  #4636
tnilc's Avatar
tnilc
Originally Posted by tnilc
Never heard of MForce.
Anyone else running the D3 tune? Looking for feed back.
I brought my RC back to the stock tune to take it into the dealer to have recall work done on my fuel pump. I hardly drive my RC anymore and honestly can't tell a difference between stock tune and my OVTune lol
I gotta say tho my drive freeway with the stock tune, my mid range was killing it with the stock tune.
mayve I jinxed myself. I tried loading my OVTube flash but it won’t, says either unsupported or corrupted. Odd because 3 weeks ago I flashed back to stock no issue. Even my stock tune won’t load, same problem.
Old Apr 20, 2021 | 09:35 PM
  #4637
rduong's Avatar
rduong
Wish I could get D3 tune. Anyone here running it?
Old Apr 20, 2021 | 09:36 PM
  #4638
tnilc's Avatar
tnilc
I love fishes because they’re so delicious.
I love fishes.
Old Apr 29, 2021 | 11:41 AM
  #4639
Sheddy's Avatar
Sheddy
https://www.clublexus.com/forums/rc-...o-upgrade.html
Old May 15, 2021 | 11:17 AM
  #4640
tnilc's Avatar
tnilc
D3 Tuned ordered, hope to get it by the weekend!
Old May 28, 2021 | 03:18 PM
  #4641
tnilc's Avatar
tnilc
Just got my D3 Tune!
Getting it uploaded today!
Old May 28, 2021 | 08:06 PM
  #4642
rduong's Avatar
rduong
How is it?
Old May 29, 2021 | 11:29 AM
  #4643
tnilc's Avatar
tnilc
Originally Posted by rduong
How is it?
Slight problem, I have an RC and it has a calibration different than the IS.
When I had my OVTune, same thing happened. The customer service has been top notch from D3. WAAAY Better than OVTune who is now ghosting everyone.
I sent some files to D3 and they'll get me my tunes by Wednesday. I am excited!
Old Jun 9, 2021 | 07:39 PM
  #4644
tnilc's Avatar
tnilc
Got my D3 Tune, LOVE IT.
Removed a lot of throttle lag and even some of my drone.
Customer service was also top notch!
Old Jun 9, 2021 | 07:45 PM
  #4645
tnilc's Avatar
tnilc
Old Jun 9, 2021 | 09:33 PM
  #4646
chezgk's Avatar
chezgk
Post Downpipe log and some OV/VFTuner notes
Finally found a way to accurately log boost after the installation of a catted downpipe in my NX. Apparently, logs within Techstream can be exported as CSVs and opened in generic log viewers like logView. This is still on then-OV's remote dyno tune. Fortunately, there was no boost creep, even past redline. I've always wondered whether or not a downpipe will provide any benefit without making changes to the tune. While I only have my butt dyno to refer to at the moment, boost comes noticeably earlier and the engine kind of slingshots once it gets past 5000 revs. A total win for me. More details on the downpipe here.
(I hope you guys don't mind my posting 200t stuff here, since performance dialogue in the NX forum is next to non-existent.)
On to VFTuner:
Quoting from OV/VFT's post in their forums:
There is a huge updating coming to the 2.0T,
new boost control maps
Map sensor scaling control
Target boost control
fixed AFR tables, corrected values
a ton of stuff.
This is huge, since our 200t's tend to stay in closed loop even past peak boost in the lower gears. (Logged this on stock, TTi, and OV tune) Closed loop = 14.7 AFR. If the latest update includes a way to get to open loop and thus run richer AFRs earlier, there ought to be some more safer power available for harvest, at the expense of a little fuel economy.
I've been playing with some throttle tables and was able to make the NX very responsive by altering Accelerator Request to Airload and Throttle Efficiency tables. Unfortunately, after just a few seconds of extreme responsiveness, the ECU hits a wall and triggers the P2119-04 code. I believe this code has been encountered by quite a few OV users in this thread. Mat posted a preview of another upcoming VFT feature, disabling specific codes. See screenshot below:
Example of DTC tab
checkmark means DTC = active
uncheck to disable for testing.
Full resolution photo here.
If this works, then even more responsiveness out of our motors could potentially be had. One can only wait.
Old Jun 9, 2021 | 10:12 PM
  #4647
GSiGuy's Avatar
GSiGuy
Sounds Great! Was the throttle lag improved on Normal mode too or just on Sport mode?
Old Jun 10, 2021 | 01:06 AM
  #4648
BMGS's Avatar
BMGS
My D3 tune is on a GS200t (should be similar) but it's mainly the Sport mode. That's a good thing because Sport mode is so responsive that its nice to have an option for more casual driving or with passengers.
From memory, I believe there was some improvement in normal mode over the stock tune but its truly night and day compared to the "new" sport mode. I've had the tune for 10 months and it's always a blast to switch to sport mode. It's always in the right gear with the turbo spooled and boost on tap for a strong low end pull when needed. It's exactly what I was looking for when I bought the 200t over the 350 mainly for suburban street driving. It does well on the highway too but the low end torque, responsiveness and the "always in the right gear feel" is really great now with the tune.
Old Jun 10, 2021 | 01:10 AM
  #4649
BMGS's Avatar
BMGS
Did you go with the higher rpm tune? I left mine at the stock shift point version considering it's out of breath above 5000rpm but curious of your impressions if you did spend any time in that higher rpm range from the modified shift points.
Old Jun 10, 2021 | 03:21 AM
  #4650
GSiGuy's Avatar
GSiGuy
Awesome! Waiting for mine to come!
