IS200t tune
Old Feb 14, 2019 | 06:37 PM
  #3616
chezgk's Avatar
chezgk
- Will the tune have higher octane fuel limitations, or will it automatically adjust/learn after filling up with minimum manufacturer recommended octane?
- I saw in your blog post that you raised RPM to 7k. Were you manually upshifting in the video, or did the vehicle still upshift by itself?
- Hope every transmission/upshift benefit carries over to the NX, despite it having a different transmission.
Old Feb 15, 2019 | 02:51 PM
  #3617
DiverseIS's Avatar
DiverseIS
Originally Posted by OrangeVirus Tuning
Note, at around 70 * C (160* F) Our temperature compensation will reduce maximum allowed throttle to 50%. This is due to how quickly the stock intercooler gets hot when you run several full throttle pulls.
The intercooler itself is not really the problem, it is the turbocharger. At high boost pressure, without the throttle limiting flow, turbocharger shaft speed is extremely high and the boost air temperature is very hot.
Where are you reading that temperature from IAT? Just wondering what temperature it's read from to try and mitigate it.
I can't believe how far you guys have come. Keep up the good work.
Old Feb 18, 2019 | 12:08 PM
  #3618
Sheddy's Avatar
Sheddy
The part out continues
Old Feb 20, 2019 | 10:18 PM
  #3619
1stwrldprb's Avatar
1stwrldprb
I changed my spark plugs at 80k miles and immediately noticed a little more pep, so I went back to the track and dropped .4 seconds off my 1/4 mile, same trap speeds. 15.1 @ 91 mph in 80 degree weather vs before when I ran 15.5 @ 91mph in 55 degree weather. Both runs were also with less than 1/4 tank of fuel. My highest trap ever was 92mph which was also tonight, but at higher ET of 15.5. I also ran next to a current camaro (either the 2.0T or 3.6) and he ran 14.9 @ 93 mph.
Old Feb 21, 2019 | 03:39 AM
  #3620
loophole35's Avatar
loophole35
Where are you located? Those seem like okay times for this car. My 2011 IS350 ran a 14.5 @ 108 at Gainesville raceway.
Old Feb 21, 2019 | 05:56 AM
  #3621
1stwrldprb's Avatar
1stwrldprb
I'm in St Cloud (central FL), went to Orlando speed world. 108mph seems like a high trap speed for an IS350, I'm guessing your car is not stock? Also, 108mph is good for low to mid 13 second times so your 60ft must have been bad, like a 2.5 60ft or so. I ran 13.5 @ 105 mph in my Z4 M so if you get your launch better you'll def. have a 13 second car.
Old Feb 21, 2019 | 06:28 AM
  #3622
loophole35's Avatar
loophole35
Sorry I fat fingered on my phone it was 13.5 @ 108. It was about 6 years ago now. I think the 60’ was like 1.7 something. I don’t have the slip anymore. I also don’t have that IS any more. All it had was lowering springs 19” wheels and a Joe-Z intake pipe. Second gen IS350’s are definitely faster than third gens.
Old Feb 21, 2019 | 07:36 AM
  #3623
1stwrldprb's Avatar
1stwrldprb
Aha! Okay that time makes more sense. I think 3rd gens trap in the low 100mph range, didn't know the 2nd gens were faster, they must weigh a lot less then because the 3IS should have a gearing advantage w/ the 8spd vs the 6sp.
Old Feb 21, 2019 | 08:12 AM
  #3624
loophole35's Avatar
loophole35
Should, however the transmission logic in the 3IS has torque tables that come into play and can reduce its acceleration. On paper the new 350 should be faster, but in practice that transmission (which is phenomenal in the ISF) is a factory of sadness.
Same is true for the IS turbo transmission (it’s the same unit). Most of us are just as eager to hear about TCM updates with the reflash as we are with throttle response and power improvements. If the transmission is still a sluggish shifting gear hunting mess it currently is with the improvement to the engine it would be a waste.
Old Feb 26, 2019 | 07:36 PM
  #3625
Is200tnc's Avatar
Is200tnc
Has anyone tried the OV update yet? Curious if anyone has gotten results they can post. Really wanted to see a comparison to the tune i have now. Hope their tune pans out. Would be a great thing for the is200t development
Old Feb 26, 2019 | 09:03 PM
  #3626
Flash5's Avatar
Flash5
It’s not out yet. They are still working on it.
Old Feb 26, 2019 | 10:03 PM
  #3627
Is200tnc's Avatar
Is200tnc
i was told they were sending it out to people who all ready had their tune set up. Ecu update.
Old Feb 28, 2019 | 02:11 PM
  #3628
OrangeVirus Tuning's Avatar
OrangeVirus Tuning
New dyno results for our updated EROM 1.01 Tuning for this engine coming in the next few days
Old Feb 28, 2019 | 03:06 PM
  #3629
WhyHateTho's Avatar
WhyHateTho
This is exciting. Keep up the great work. Thank you.
Old Feb 28, 2019 | 10:52 PM
  #3630
glowix's Avatar
glowix
I've implemented TTI in my European IS300.
After the experience with Racechip box believe me you don't wont to have any other boxes. Wasting of time.
You can reverse to stock anytime as well.
