Dyno Tuning
Old Jan 2, 2013 | 11:00 PM
timtim14's Avatar
timtim14
Default Dyno Tuning
I am hoping to dyno tune my gs4 as to squeeze all the power out of the headers, exhaust and intake but i have been searching CL for awhile now on this subject and i cant get a clear cut answer. People say that the ECU can not be reprogrammed or can only be done temporarily because it relearns itself or goes back to factory settings? Others say that its worked for them. Can someone please give me a clear cut answer as to whether our cars can or can not be tuned or if we need a piggy back or standalone to make this possible. Thank you.
Old Jan 2, 2013 | 11:34 PM
818GS's Avatar
818GS
You can only change the air/fuel ratio with a piggyback. Thats it.
Old Jan 3, 2013 | 06:22 AM
neegroy's Avatar
neegroy
i think your better off getting the srt intake.
Old Jan 3, 2013 | 01:40 PM
MoncefGS's Avatar
MoncefGS
Get an SRT intake and use an SAFC to tune the air/fuel ratio on the dyno. The tuner will be able to find the best AFR for power there. But get the intake first, since it will add quite a bit of power.
Old Jan 3, 2013 | 05:22 PM
Durrby's Avatar
Durrby
Here's some food for thought, I have the SRT intake (from the gs400) on my '99 sc400. I made 235whp before the intake and 239whp after.
Old Jan 4, 2013 | 07:09 AM
MoncefGS's Avatar
MoncefGS
Whaaaat? Can you post the dyno charts?
Old Jan 4, 2013 | 09:46 AM
Durrby's Avatar
Durrby
back in '10 before the intake
from a month ago with the intake
Old Jan 4, 2013 | 03:04 PM
mk2tmr2's Avatar
mk2tmr2
Hate to say it, but it looks like the only reason the more recent dyno made more power may be because you revved it higher. Torque only increased by 1lb/ft.
Simply reflashing or throwing piggybacks on an otherwise stock car isn't going to get you much gain unless the car came with forced induction from the factory. With a turbo you can usually squeeze an appreciable amount of additional power out by helping it breathe more, turning up the boost 1 or 2 lbs and tuning less conservatively than the factory.
With a N/A car there doesn't tend to be tons of power left on the table by the factory.
My Miata makes around 110whp bone stock on a Dynojet. With a full intake, header, exhaust (with a factory cat) and a majorly built head and intake manifold running a full stand-alone it made 140whp. That's only 30 more hp for about $5,500 in mods.
Granted...all that has been done in preparation for a turbo which will make the number closer to 300whp But I digress. The point is that "tuning" a naturally aspirated car on the dyno is only worthwhile if you have done a ton of work to the motor. And even then you can't expect easy gains like you would with a boosted car.
Of course, some exceptions do apply.
Old Jan 4, 2013 | 06:07 PM
99 GS3's Avatar
99 GS3
Huh??? This is just completely untrue.
There are piggybacks that can control ignition timing, injector pulsewidth, fuel pump control, nos control, launch control, boost control, 02 skewing, fuel type detection/map switching, data logging, etc, etc...
Old Jan 5, 2013 | 06:42 AM
Hardrvin's Avatar
Hardrvin
Though I agree it "only 30 HP" consider the % increase over stock. That's actually fairly impressive.
And 99 GS3 is right. Importantly, the o2 does function can prevent the ecu from relearning per the OP concerns.
Old Jan 6, 2013 | 07:32 AM
Rock-a-Lex's Avatar
Rock-a-Lex
Disagree. I threw on my Apexi Neo almost 5 years ago on my GS4 and the tune still stuck to this day; gained around 20whp and 18wtq iirc. Dont feel like posting anymore dyno charts...did that a while back. Search my old threads.
With my stock whhels on, the car made 282whp and 306wtq. All my mods are in my sig. I leave a 20' streach off the line with my 275's on; the car has good power for being NA with some bolt-ons. Fyi, I remember the tuner said he will only tune the car for more power at WOT. He mentioned everything else would be a waste as the ecu overtime will override the part throttle adjustments.
Old Aug 18, 2013 | 10:29 AM
scENFORCER's Avatar
scENFORCER
With my BFI, and full header back exhaust I gained 35whp (assuming Durrby's stock SC numbers are the same as mine). I've been looking at getting a supporting but conservative tune and was hoping for 20-30whp more. Perhaps even a manual swap down the road which should release even more hp.
Old Aug 19, 2013 | 08:24 PM
rwheelz's Avatar
rwheelz
Durrby- did you run the car a couple hundred miles after install before going back to the dyno? We just installed the SRT intake and it made substantial gains on my car. I notice your A/F is the same before and after, on my car the SRT ECU leaned it out quite a bit.
Old Aug 20, 2013 | 06:02 PM
Durrby's Avatar
Durrby
I'm not sure how power on dyno's are measured but that sheet says 270 flywheel hp. Does that mean you still have to account for drivetrain loss which would make that number lower?
Yes, the intake was installed almost a year to the day when it was redynoed.
Old Aug 21, 2013 | 10:58 AM
scENFORCER's Avatar
scENFORCER
Not unless I removed the engine to get those numbers. Dynos are at the wheels. Mine is still auto so I think that 'flywheel horesepower' is just how they label their dyno sheet?
