Installing F intake-Have any tips?
Old Dec 12, 2010 | 12:09 AM
gbs350F's Avatar
gbs350F
i did it ONLY using the instructions that come with it and i was pretty good. every time u take something off (bolts, clips, etc.) lay them down on the ground where they should go in the car, that goes for panels too. It makes cleaning up far easier.
Old Dec 17, 2010 | 06:42 PM
Lexs350's Avatar
Lexs350
F Intake installed. It was'nt bad at all. The DYI and tips from you all helped alot. I only had one problem. My windows did not work in "Auto" after I reconneted the Neg Battary terminal. I found the instructions in how to reset each window in the owners manuel and now working as advertised.
I will attempt to post pics in the near future.
Thanks again guys
Old Jul 22, 2011 | 10:21 PM
Chow's Avatar
Chow
Post how to fix the windows. I am doing the install tomorrow.
Old Jul 22, 2011 | 10:34 PM
wyee99's Avatar
wyee99
^ roll down the window half way and roll it back up.. then the "auto" switch will work.
Old Jul 22, 2011 | 11:46 PM
Salduchi's Avatar
Salduchi
Did my Intake this week. Never even disconnected the battery. Problem now is I keep steppin on the gas just to hear the.....WAAAAW!!!!!
Old Jul 23, 2011 | 01:00 PM
Chow's Avatar
Chow
just did mine and did not disconnect the battery. Is there an advantage to disconnect the battery?
Old Jul 23, 2011 | 01:13 PM
brociouz's Avatar
brociouz
^ You reset your engine ECU so it can get used to the intake.
Old Jul 24, 2011 | 09:37 AM
Kurtz's Avatar
Kurtz
But it does that anyway.
The ECU is always learning.
Resetting it doesn't accomplish anything except losing some current vehicle settings.
Parsa
Performance
Jan 9, 2016 09:52 AM
Stevenhy92
Performance
Jan 25, 2014 11:06 AM
kegleyb
Feb 27, 2012 01:13 PM
suhermanj
Dec 2, 2004 06:22 PM
