Fujita intake question/problem
Old Sep 4, 2010 | 01:35 PM
heyarms's Avatar
heyarms
Question Fujita intake question/problem
Just got/installed a fujita intake on my is250.
The small hose coming from the engine that hooks up to the middle of the intake pipe ended up a little too short to reach the pipe... is this normal? Does everyone just go buy a small section of tubing to replace this or what? I ended up using electrical tape ( ) to make it stay and reach, otherwise it would pop off, even with that flimsy little stock clamp.
Any pointers/ideas/suggestions? I got a feeling the tape will melt but i had to run some quick errands so i did what i had to!
Old Sep 4, 2010 | 01:46 PM
new.era.13's Avatar
new.era.13
i had the same problem with takeda intake. i just pulled as hard as i can to reach it and zip tied it and its good.
Old Sep 4, 2010 | 02:03 PM
heyarms's Avatar
heyarms
Yeah i guess i might just buy a better small hose clamp and call it a day, but the hose is definitely too short
Old Sep 4, 2010 | 02:29 PM
new.era.13's Avatar
new.era.13
they are. you can always try and buy a longer hose. its only a air hose.
Old Sep 4, 2010 | 04:01 PM
funglenn's Avatar
funglenn
I just put this intake in, i figured out the hose you guys are talkiing about--and the MAF sensor is easy. However where do you mount the mounting point? I cannot figure that out. I have hte long screw with the bushing in it, just don't know where to put it in to keep the intake from wabbling around.
Please help!
Old Sep 5, 2010 | 01:36 AM
Kenji07250's Avatar
Kenji07250
you're talking about the vacuum hose? mine fitted just fine. The Fujita intake should've came with a hose clamp. You're not suppose to use the OEM spring clamp.
Old Sep 5, 2010 | 01:44 AM
Kenji07250's Avatar
Kenji07250
Please help!
The long screw with the bushing is suppose to be mounted
Old Sep 6, 2010 | 05:20 PM
funglenn's Avatar
funglenn
Thanks got it now! A bit wobbly but good to go!
Old Sep 6, 2010 | 11:10 PM
Kenji07250's Avatar
Kenji07250
if its still a bit wobbly. Loosen the clamps on the throttle body and twist the intake until it bolts up well with the screw
Old Sep 7, 2010 | 06:10 AM
06isDriver's Avatar
06isDriver
that little mounting tab is sorely lacking in my opinion. I would expect that when you buy a $300 piece of pipe that they would have at least engineered a more suitable mounting location.
I guess you dont get much for what you pay for these days.
Also, if your vacuum hose is not long enough, DO NOT STRETCH IT TOO FAR or you will get a cel code (p0101,p0102) caused by a kink when the engine flexes on it mounts.
You can go to any auto parts store and ask for a 180 degree bend heater hose that will be long enough.
Old Sep 7, 2010 | 11:38 AM
Kenji07250's Avatar
Kenji07250
I got my fujita for about $160. So not much of a biggie. Hey how's the A/C intake coming along. Interested in the progress
Old Sep 8, 2010 | 11:13 AM
06isDriver's Avatar
06isDriver
its coming, pressing hard to hit my deadline.
ChazZ
Aug 8, 2022 06:27 PM
tuanyes84
Performance
Mar 11, 2017 09:19 AM
Haichew
IS F (2008-2014)
Sep 26, 2014 11:33 AM
es5240
Nov 30, 2011 12:11 PM
JoeCombs
Jan 18, 2011 03:18 PM
