Problem for my Joez street performance exhaust
Old Jun 19, 2010 | 06:51 PM
MKsky's Avatar
MKsky
Default Problem for my Joez street performance exhaust
I just install my joez street performance exhaust(the one with extra cats). The check engine VSC light came up after the shop installed them. is that normal? how do i solve it? i heard there is a thing call o2 sensor adaptor, but i dont' know which one should i get, any suggestion?
After the shop install the exhasut, the left side is much lower then the right side and it's very noticable. How do i make them to be equal?
Need help ASAP
Mark
Old Jun 21, 2010 | 12:21 PM
MKsky's Avatar
MKsky
No one can help me out on this?
Old Jun 21, 2010 | 12:25 PM
xuningshen's Avatar
xuningshen
you should ask joez himself. he's on the forums. send him a pm
Old Jun 21, 2010 | 12:31 PM
iSuxeL's Avatar
iSuxeL
It shouldn't go on. I installed the RACE version and didn't get anything.
Old Jun 21, 2010 | 03:43 PM
Joe Z's Avatar
Joe Z
Hi Mark,
The exhaust does not cause any CEL lights. The problem must have occurred with install and possible damage to O2 sensor or wiring.
The rear flanges are adjustable and can be turned to make the Tips sit higher or lower.
Who did your install?? and did you have the code read yet??
- My guess is that it will come back to one of the O2 sensors that were touched during install.
Let us know.
Joe Z
Old Jun 21, 2010 | 03:49 PM
blk250's Avatar
blk250
where are U in CA?
I have the same exhaust installed, still have not get any errors yet!..
Old Jun 21, 2010 | 04:09 PM
MKsky's Avatar
MKsky
Originally Posted by Joe Z
Hi Mark,
Let us know.
Joe Z
What do you mean by touched? if was touched, what should i do? clean it and reinstall or i have to replace them?
Mark
Old Jun 21, 2010 | 10:03 PM
acefalcon2's Avatar
acefalcon2
same here no probs with my JoeZ Exhaust... might wanna check that all the clamps are actually tight... mine was a little loose close to the o2 sensors... thus some air could go in... throwing off codes....
the other thing about the one side hanging lower... might want to twist and turn the bolts and make sure all are snug and tight... last resort is stainless steel zip ties
Andre
Old Jun 22, 2010 | 04:23 PM
Joe Z's Avatar
Joe Z
Lightbulb
Mark
I mean touced as in worked on...
The #1 problem for CEL's after a Full Exhaust install is damaged or mishandled O2 sensors and/or its wiring.
For example if you crawl underneath there and see all the wiring bound up, that would be a key indication of a problem.
What city are you in?? We have experienced installers in NorCal & SoCal...
The Tips are easy to line up.. They are adjustable by design..
The 2 rear axle sections are flanged as you can see...
There is room for adjustments to those 4 bolts, which will control how high / low the tips sit off the bumper exhaust cut out holes.
For example on my car when we first installed it and took pics, there was a 2 finger gap.. After the exhaust burned and settled in its place, I went back and loosened the 2 rear sections and adjusted as high as I could..
Which is just about a 1 finger gap now...
Perfect if you're running an aftermarket lip and want to adjust how high or low you want the exhaust tips to sit.
The mufflers are not lower than stock. If anything they might be just as high or slightly higher..
They are just a lot more visible since they are polished.
The tip design is finalized for these two versions.
Before adjustment
After adjustment
Passenger Side flange at rear axle section can be turned all the way to the max Left to go higher before tightening..
Drivers Side flange at rear axle section can be turned all the to the max Right to go higher before tightening..
- Vice versa for going slightly lower
It will take some trial & error to get both Tips perfect, but an extra set of eyes helps very much too..
Joe Z
Old Jun 22, 2010 | 11:24 PM
MKsky's Avatar
MKsky
I'm in socal, i go to fnm every week!
Old Jun 23, 2010 | 07:05 AM
Joe Z's Avatar
Joe Z
Lightbulb
Ok this should be easy....
Who did your install???
If it wasn't Tommy @ Musicbox, I recommend a quick drive over there to see how the install was done..
Tommy has installed quite a few of these here in SoCal and is very experienced with our design.
Including many IS-F systems.
Joe Z
Old Jun 23, 2010 | 12:46 PM
MKsky's Avatar
MKsky
I was about to go to tommy for installation but the exhaust system was too big that i have to call my friend to help me out and he doesn't want to carry all the way to tommys place so i just find a local shop call promax to install it for me. then the out come is this. i just check the new set of o2 sensor from sewell lexus and it cost 177 for new set which is way out of my buget. i'm not sure if mine o2 sensor can be fix or not.
Old Jun 23, 2010 | 01:04 PM
Joe Z's Avatar
Joe Z
Arrow
The PTS exhaust fits in the trunk easily... it's 4 sections..
Bringing the OEM exhaust home would have been your only issue.
My BEST suggestion is to take it to Tommy to have him inspect the install and O2 sensos / wiring.
He can easily tell you whats going on.
I was planing to visit Tommy this well as well.
Joe Z
Old Jun 24, 2010 | 01:18 AM
MKsky's Avatar
MKsky
I went to musicbox today and tommy can't figure out why the check engine light is on as well. the sensor looks fine. i'll probably bring it in to dealer to get the codes. werid!
Old Jun 24, 2010 | 03:47 PM
MKsky's Avatar
MKsky
Codes has be read!
number P0157, p0158 and p0606.
both p0157 and p0158 are o2 sensors.
Cause: Low voltage on lt rear o2 sensor. Twisted. Excessive Resistance.
Cost of replacement: 454 plus tax.
What should i do now?
