IS350 torque converter??
Old Apr 18, 2009 | 12:42 PM
iSuxeL's Avatar
iSuxeL
Default IS350 torque converter??
Anyone seen this?
http://cgi.ebay.com/ebaymotors/LEXUS...Q5fAccessories
Old Apr 18, 2009 | 01:54 PM
Robs IS250's Avatar
Robs IS250
what about it? LOL....
Old Apr 18, 2009 | 03:43 PM
Kurtz's Avatar
Kurtz
Looks like someone learned how to bend impeller fins when they rebuild a torque converter
Old Apr 18, 2009 | 04:14 PM
L-S-D's Avatar
L-S-D
uhh wat does it do tho? lol
Old Apr 19, 2009 | 01:51 AM
CallmeHoku's Avatar
CallmeHoku
converts torque. lol idk. but it looks interesting. I would like to know also.
Old Apr 19, 2009 | 06:41 PM
four o two's Avatar
four o two
I don't see a necessity for a torque converter on our cars. A big single'd, cammed auto Supra... yeah, but a stock IS? Nah.
Old Apr 19, 2009 | 10:01 PM
eric_r_ho's Avatar
eric_r_ho
The factory one is good enough. The reason why people have these high stall TC's is so that they can launch their HIGH-POWERED automatic transmissions at a certain RPM when they're racing. The IS250/IS350 is not a high-powered vehicle so nobody will ever need to upgrade from the factory TC.
Old Apr 20, 2009 | 06:35 AM
iSuxeL's Avatar
iSuxeL
Even with boost?
Old Apr 20, 2009 | 07:52 AM
Kurtz's Avatar
Kurtz
With as little boost as the 2IS can run that doesn't change the equation much.
For folks who are 1/4 mile racers even on stock HP the 350 (or any auto) is likely to benefit from a higher stall converter...
It's virtually useless, from a performance perspective, for anything but launching the car though.
Now, this one appears to just be a rebuilt converter with the fins bent to raise the stall speed a bit... it'd probably knock a tenth or two off the ET on the 1/4 mile... if that's worth the expense of swapping your TC that's up to you.
What usually shows -real- benefit (like 3-5 tenths) is a smaller converter with a significant stall speed increase.
On GM b-bodies for example the stock TC stalls around 1200-1400 rpms and is a 12" converter... you can swap in a stock 12" from a vette for a similar price to this unit, that raises the stall to 1800-2000 and knocks .1-.2 off the 1/4 mile... but buy a 9.5" converter with a stall in the 2800-3200 range and you're knocking .3-half a second off your 1/4 mile depending on other mods. You're talking 600-1k for one though.
I dunno if anyone makes aftermarket TCs for this transmission though, so a rebuilt stocker might be the only current option.
Anyway, again, this is something for the drag racers to look at, but probably not worthwhile for anyone else.
Mrg02d
Aug 29, 2016 03:18 PM
Rock-a-Lex
Performance
12
Sep 5, 2007 06:01 AM
