Gs3 transmission
Old Oct 7, 2008 | 07:08 PM
fordsvtmfl's Avatar
fordsvtmfl
Default Gs3 transmission
What kind of power will a stock gs3 auto transmission be able to withstand?
Also what manual transmissions will bolt onto/work with the 2jz?
Thanks
Old Oct 7, 2008 | 07:16 PM
GS300Jason's Avatar
GS300Jason
maybe around 380-400 flywheel hp. i'm not sure about the transmission question.
Old Oct 7, 2008 | 08:23 PM
shvc1991's Avatar
shvc1991
http://l-tunedparts.com/product/?id=1161
There's for the transmission question.
Old Oct 7, 2008 | 08:35 PM
fordsvtmfl's Avatar
fordsvtmfl
i know that transmission will work, i was talking about other transmissions like the 5-speed found on the mkIII supra, the W58 and R154. Because you can get your hands on those for about $500-$1000...and for a 5K difference, i could deal with any down sides... lol
Old Oct 7, 2008 | 08:48 PM
shvc1991's Avatar
shvc1991
I believe the tranny from the MKIII Supra will work(R154), but you will need the bell housing and flywheel from the 1jz.
**EDIT** - Went google searching, ended up on the Supra forums and found out you should probably get the flywheel bolts too. A user by the name of "SUPRASTANGER507mgte" says you will need 8 of them and a few other users backed up this info. Another thing you will need is the 7M-GTE clutch kit which consists of a clutch, pressure plate, pilot bearing, and throwout bearing. I also read that the 2jz flywheel will work with the R154. You will just need to redrill it to match the R154 pressure plate.
Old Oct 7, 2008 | 08:57 PM
fordsvtmfl's Avatar
fordsvtmfl
thanks for the info...so what am i looking at on the electronics side of it? do i need a all new ecu?
Old Oct 7, 2008 | 09:01 PM
shvc1991's Avatar
shvc1991
Sorry man, I can't seem to find anything on that. Try searching around the Supra forums. Some GS3 owners lurk around on them, many with standard transmission swaps.
Old Oct 7, 2008 | 09:03 PM
shvc1991's Avatar
shvc1991
You could even search on here. Some members have swapped out their transmissions. You could probably ask them. I doubt they would mind you asking a few questions.
Old Oct 7, 2008 | 10:10 PM
GS300Jason's Avatar
GS300Jason
I contacted someone that was located in Austin TX, and their shop specializes in Supras, they told me they can rebuild one and install it for around 3000-4000. Try looking around you locally. Someone around you might be able to do a valve body job.
KahnBB6
Jan 20, 2016 08:04 AM
disp0sal
GS - 1st Gen (1993-1997)
16
Jan 16, 2014 10:07 AM
Irslopra
Aug 17, 2010 07:14 PM
Derf
Jun 27, 2004 08:56 PM
