VSC after installing a cold air intake
Old Jul 2, 2008 | 06:15 PM
Sytfu_IS's Avatar
Sytfu_IS
Unhappy VSC after installing a cold air intake
I just installed a Fujita CAI and my VSC light went on and traction control light. How to fix it?
Old Jul 2, 2008 | 08:34 PM
Zexnos's Avatar
Zexnos
I mean this in the nicest way possible, but you did something wrong...
There is little to no way that an intake caused this.
Please tell us how you installed it...
Old Jul 3, 2008 | 07:12 AM
Gernby's Avatar
Gernby
First, the only "cold air" intake currently available is the stock intake. All the other ones are "hot air" / short ram intakes. They sound neat, but don't improve performance.
Second, you probably have a leak. I would recheck the MAF sensor to make sure it is seated well with a good gasket, then check the big hose clamps at the throttle body.
Old Jul 3, 2008 | 07:20 AM
passnu2's Avatar
passnu2
Bingo These are not doing anything for your car
agree this is something that you can easily correct.
Old Jul 3, 2008 | 07:21 AM
orlando628's Avatar
orlando628
yea it the maf sensor u probably killed it hapen to me with my old vw jetta gli but it was cuz i put the sensor backward check if isnt backward if not the sensor died
Old Jul 3, 2008 | 08:25 AM
Gernby's Avatar
Gernby
A leak is far more probably than a damaged sensor ... unless the OP added more oil to the pre-oiled cotton filter...
Old Jul 3, 2008 | 08:45 AM
orlando628's Avatar
orlando628
yea could be both unless he test it put the stock back on and see if u get the vsc n traction and remove the battery for like 10min that resets the computer actually do that now wit the new intake on if it doesnt go away put the stock n do the same if that doesnt work then ur sensor is damage
Old Jul 3, 2008 | 08:55 PM
Sytfu_IS's Avatar
Sytfu_IS
It ended up being nothing guys, it stopped showing up after an hour and a few restarts : D
Old Jul 3, 2008 | 09:00 PM
Sytfu_IS's Avatar
Sytfu_IS
khizr23
Nov 21, 2018 07:02 AM
YODAONE
Apr 14, 2016 08:00 PM
stevoman96
Oct 3, 2014 11:24 AM
BiggDatty
Performance
Jan 21, 2014 06:50 AM
scorpero
Performance
May 26, 2006 02:26 PM
