2jz swap
Old Jun 16, 2008 | 08:15 PM
  #31
illmike's Avatar
illmike
ohhh damn. your the man...50k for the swap tho?
Old Jun 16, 2008 | 08:19 PM
  #32
Pnuge88's Avatar
Pnuge88
Hes Got The Money So Why Not? The Is Body Styling Is Sexy And Now Kills A Majority Of Cars On The Road.. And Its A 250! Lol
Old Jun 16, 2008 | 08:27 PM
  #33
darkdream's Avatar
darkdream
Wow talk about a sleeper!!!...
Old Jun 16, 2008 | 09:57 PM
  #34
Robs IS250's Avatar
Robs IS250
yes sir speed shop did it and the guy spent $35k total between the motor, getting it fully built, and the swap
Old Jun 16, 2008 | 10:29 PM
  #35
boostdream's Avatar
boostdream
i just wanted to do something difrent yea i spent about 35k but then it got ugly when i found out i had to change diferential,axles,suspension,tighten up the chassis,internals thats when the list banged up to 50k but wat can i say its just a car like every car in this forum.......lol
Old Jun 17, 2008 | 11:32 AM
  #36
iceman1117's Avatar
iceman1117
Yeah just like every car in this forum just with a 2jz in it lol
Old Jun 17, 2008 | 12:40 PM
  #37
badx33's Avatar
badx33
july 25,26,27 is the next big lexus /toyota meet at j&M LEXUS IN marget,fl
Old Jun 17, 2008 | 02:05 PM
  #38
uschardcor's Avatar
uschardcor
how could you not think that? the 2is definitely wasn't built for 400hp let alone 1000, or 1200. what transmission are you using? why is it that the block seems to be tilted towards the back, optical illusion? and just out of curiosity, is english your first language?
Old Jun 17, 2008 | 02:51 PM
  #39
darkdream's Avatar
darkdream
are there any video clips of the car in action?
Old Jun 17, 2008 | 03:28 PM
  #40
Gernby's Avatar
Gernby
Are you sure the stock differential and axles really needed to be replaced? The amount of stress on those components is really limitted pretty much by the grippiness of the tires, so I wouldn't expect them to fail much faster whether you had 300 HP or 1000 HP. I figure it's a lot like putting massively oversized brakes on a car that has crappy tires. The tires can only do so much ...
Old Jun 17, 2008 | 03:33 PM
  #41
Gernby's Avatar
Gernby
^^^ on second thought, if you have a manual transmission with a strong enough clutch to hold a ton of HP, then I guess you could pretty easily shatter the stock differential just with drive line shock.
Old Jun 17, 2008 | 05:52 PM
  #42
uschardcor's Avatar
uschardcor
what i was thinking. and replace my hp arguments with tq, thats what would break components
Old Jun 17, 2008 | 06:02 PM
  #43
Gernby's Avatar
Gernby
In the case of broken drivetrain components, I still don't think torque from the engine is really that much of an enemy with street tires. It only takes a couple thousand ft-lbs of torque to break street tires loose (1st gear with 250 ft-lbs at the crank). However, with a brisk clutch engagement with a super strong clutch and heavy flywheel, the instantaneous shock to the drivetrain could be many, many times the amount of torque the engine can provide.
Old Jun 17, 2008 | 07:00 PM
  #44
boostdream's Avatar
boostdream
the reason why i did work in the rear end is because the stock diferentials on the i.s are good for basic motor work and if i try to launch with them at the track am going to end up in the same spot then again with a set of slicks you need some good diferentials and stronger axles. the transmission am using is a speed tranny with a stage 3 spec clutch i know its kind of noisy but thats wat i need to not have trouble.
Old Jun 17, 2008 | 07:09 PM
  #45
boostdream's Avatar
boostdream
so far things are looking good i should post a video by friday of the car on the dyno.
