mazzuri super headers
Someone in one of the previous posts had commented in the weld's appearance. The reason why they looked the way they did was more than likely from the oils that were on the pipes during welding. Even if you throughly clean the mandrel bends there is still oil on them somewhere. You could excersize a lot of precaution and place them in a furnace, burn off the oils and then let them cooloff before using them. Its an unnecessary step that most of us would rather pass. The flow of the exhaust will not care what your headers look like from outside. OEM manifolds are machine MIG welded. Its how they keep costs down. These are stainless steel that have been Heli-arc TIG welded by hands of an experienced welded. It has been my experience that penetration is more important than apperance. [ask any lady that....
] These headers do a job and a half by uncorking the flow restriction at the OEM manifolds. We should have the sims installed soon and then see how it all goes thereafter. Then its just a matter of researching the ecu's ability to adapt to the increased flow and excepting the sim's output.
I'm still trying to recoop (sp?) from the long night of work. We installed them Tuesday. Yesterday I hung out (tradition) with the DFW supra crowd and didn't crash until midnight. I'm looking forward to having a long night of sleep tonight.
I had not idea there was a DFW meet. I'm sure Troy and I should be able to make it out there. Nick01 could you PM me the details. Thanks in advance.
Just hang in there guys. More info to be out shortly. We'll get back to you guys shortly. Both, Troy and I appreciate everyone's patience.
-Joe
Here's some pics. I have some more pics that I will post up for a DIY in a separate thread here in a few days.
the last pic is the flange connection I was a little worried about. I think it's fine though.
What sequence did you use to tighten down the headers? Bolts near the engine first and then the bolts at the exhaust pipe flange or the other way around?
I am certainly not going to question anyone’s work but I know that Daniel suggests to tighten the two bolts at the lower exhaust flange first. This helps to make the flanges fit together more square. When I was in the process of putting on my set, until I discovered a fitment issue with the driver’s side header, I could line the passenger side flange up perfectly.
Do both lower flanges look the same as the picture that is posted. Maybe it does not matter because of the aluminum crush gasket but….
Regards,
Regards,
so do you have any cats now with these headers?? if i recall you had the 2nd set removed??
Just like oem......
