nos?
Old Dec 6, 2007 | 03:08 PM
  #106
Lextasy89's Avatar
Lextasy89
so it wont we a true dual will it? or are you gonna cut the piping thats the 2 into 1 on the hks and just use the mufflers and tips
Old Dec 6, 2007 | 03:37 PM
  #107
Gernby's Avatar
Gernby
True dual exhaust isn't beneficial. There needs to be some sort of connection between the 2 pipes to improve scavenging.
Does anyone have a link to a dyno plot showing the difference an N2O system makes? I'm curious what it will look like. I'm picturing a graph in my mind with peak torque gain at the lowest RPM then drops off linearly as RPMs climb. Wouldn't it be sort of opposite from a centrifugal super charger? Basically if you started spraying at 2000 RPMs, torque output would be 400+ ft-lbs, or something?
Old Dec 6, 2007 | 03:46 PM
  #108
jimmyjazz's Avatar
jimmyjazz
http://www.ls1tech.com/forums/showthread.php?t=825273
Old Dec 6, 2007 | 04:15 PM
  #109
Gernby's Avatar
Gernby
Jeremy,
I'm curious how your system handles VDIM. Does it automatically quit spraying when VDIM shuts the motor down due to wheel spin?
Old Dec 6, 2007 | 04:20 PM
  #110
Gernby's Avatar
Gernby
Thanks! So it makes the torque curve less flat, and makes the HP curve more flat. That would REALLY change the thrust curve that I posted above. It might even make the optimum shift points below redline. I bet it feels like a big V8 that has big ***** down low, then looses steam up high.
Old Dec 6, 2007 | 05:08 PM
  #111
Gernby's Avatar
Gernby
Red is torque and black is HP. The percentage change is MUCH greater down low than it is up high.
Old Dec 6, 2007 | 05:39 PM
  #112
jimmyjazz's Avatar
jimmyjazz
There are some interesting thread's, faq's etc. in that forum too. They're all V8 LSx but it's still "the nitrOs" *long O*(V8 slang instead of "nos")
Old Dec 6, 2007 | 05:51 PM
  #113
Lextasy89's Avatar
Lextasy89
that link wont work for me
Old Dec 6, 2007 | 05:58 PM
  #114
jimmyjazz's Avatar
jimmyjazz
Try going to ls1tech.com, nitrous,and "Nitrous results on my 07 TBSS" sorry I know very little about computers and the net other than to clic!
Old Dec 6, 2007 | 06:10 PM
  #115
HKS350's Avatar
HKS350
This is almost how it feels. But when spraying you can really feel the cams change. Its a surge of torque then a shot of HP up top.
It does seem to lose steam at 6000 rpm though. I just thought it was a cold bottle.
Old Dec 6, 2007 | 06:15 PM
  #116
HKS350's Avatar
HKS350
Jeremy,
Well I have the TPS sensor as my trigger, so it pops on-off-on-off etc.. I have to disable VDIM when using NOS. The TPS drops to 62% open every time it sees wheel spin. Thats below trigger voltage for the ZEX. It would be impossible to program the ZEX box of these high and lows. Its just to dumb
Old Dec 6, 2007 | 06:22 PM
  #117
HKS350's Avatar
HKS350
I'll have true duals. I'm going to bolt to the mufflers. And toss the HKS Y-pipe. I was at a Dyno pull over this past weekend. All V8's. I noticed that the guy's with H-Pipes made more torque and the x-Pipe made more HP . I'm a torque kinda guy. It seemed that the H-pipe had more bottom end. I'm thinking this will help my 60' times.
Old Dec 7, 2007 | 12:28 AM
  #118
Lextasy89's Avatar
Lextasy89
^^ arent the hks mufflers fit for 2.25" tubing... I dunno if it matter though, also you say your more of a torque kinda guy.. well wouldnt 2.25" piping be better for torque and 2.5" tubing be better for top end hp?
Old Dec 7, 2007 | 04:23 AM
  #119
caymandive's Avatar
caymandive
11 Second Club
If you research exhaust systems in more depth, it's not necessary about the sizes as much as it's about obtaining maximum exhaust velocity.
Old Dec 7, 2007 | 10:10 AM
  #120
Lextasy89's Avatar
Lextasy89
i tried to find more info about this^^ but didnt really get anywhere.. but I had just heard the 2.25" would be better for torque and 2.5
' would be better for hp on our cars
