getting a tc installed and transmisson cooler too
Old May 12, 2007 | 08:30 PM
GSteg's Avatar
GSteg
You shouldn't have to get LSD and headers to fully utilize the TC.
The TC makes the most difference of all mods, aside from force induction.
Old May 12, 2007 | 10:30 PM
GS FONZy's Avatar
GS FONZy
Originally Posted by GSteg
Did you floor it from a stop or did you try to do it while the brakes were engaged?
I can do burnouts easily, but smoking the tires from a launch without brake torquing is rather hard.
from a stop and with 20s, but the stocks smoke way longer, even through 2nd gear.
Old May 13, 2007 | 06:52 AM
TonY_G's Avatar
TonY_G
Im assuming the Lextreme TC is a good quality unit, but at the end of the day it is the same stock TC with higher stall speed,
personally i would have paid a lil more and ran the PI TC, because it's designed from scratch and 99% of all members swear that they'll do it all over again,
so it's either that your TC is not as good as PI, or there is something wrong with the unit or install,
cause u should feel your rpm's shooting up and car feels like it can free rev much better...harder, quicker, and smoking all tires without VSC should be so easily done.
also, do u feel the heat from under your feet? transmission part? cause i know i get that sometimes if i really really run the car hard in a 100degree day,
hope this helps, GL on finding the problem,
but i would suggest it's your lextreme TC that's the problem
Old May 13, 2007 | 10:33 AM
GSteg's Avatar
GSteg
Maybe its a defective unit. Someone else on here had a Lextreme unit and he said it made a huge impact on his car.
Old May 15, 2007 | 08:23 AM
UZ214's Avatar
UZ214
my friend drove my car he tells me there is a significant difference in the pick up and i feel it too now, its weird the car is faster but wasnt so righ after the install maybe the ecu needed to learn?
Old May 16, 2007 | 02:39 AM
GILLEXUS's Avatar
GILLEXUS
As far as the heat issue the TC does generate more heat but the cooler should take care of that. Maybe the cooler is connected wrong??
Old May 18, 2007 | 12:12 PM
UZ214's Avatar
UZ214
okay, this is kinda weird by has a little shake on the idle, no matter what gear that car is in..never had it before..happened after the TC install..any ideas i am taking my car back tommorow
Old May 22, 2007 | 07:31 AM
UZ214's Avatar
UZ214
update
the mechanic tells me the shakes at idle at any gear other than neutral this is cuz the TC is not balanced correctly ??
Old May 22, 2007 | 09:18 AM
Rock-a-Lex's Avatar
Rock-a-Lex
What does this mean...not balanced correctly? Is this an install error or a defect in the TC? I would like to know as well.
Old May 25, 2007 | 02:52 PM
akitamike's Avatar
akitamike
ely sounds wrong.
Old May 28, 2007 | 11:27 PM
UZ214's Avatar
UZ214
its a defect in the TC , its like a wheel its needs balancing, if not balanced correctly you would feel vibration on idle or certain rpms, i just ordered another dragon one.. i have to pay to install again around 500$ i ampissed off
Old May 29, 2007 | 05:44 AM
Rock-a-Lex's Avatar
Rock-a-Lex
...and let me guess, Precision Industries will not "help" with your additional labor expense of the new install? I think that's such BS because there is NO WAY of telling if you received a defective TC until you spend the $500-600 for installation...then you find out it's defective and un-install it, send it back get a new one and then pay another $500-600 for the new install; NOT COOL MAN! Sorry for your stupid ordeal...I feel for ya.
Old Jun 13, 2007 | 06:40 AM
Rock-a-Lex's Avatar
Rock-a-Lex
Oops sorry I meant Lextreme...Sorry precision Industries. What ever happened with this is your car running right with the new TC yet?
dsouth
Southeast
Aug 7, 2006 07:20 PM
noop
Performance
Feb 19, 2006 08:35 PM
mdwtexas
Performance
55
Aug 23, 2005 04:20 PM
tomtnc
Performance
Mar 17, 2003 06:09 AM
supercoupes
Jun 23, 2002 02:40 AM
