Problem with my supercharger/engine.
Old Jul 26, 2006 | 10:34 PM
mikeyboy's Avatar
mikeyboy
Default Problem with my supercharger/engine.
Well today my car was giving me a pretty big problem 2GS3. The car at around 4800rpm's +- 5lb's of boost the car begins to like put, put, put, put rapidly, continuously, and powerless. The putting starts around 4k rpms and continues to about 4800 where it really doesn't give out any power, although i am boosting. It's almost identical to me hitting the rev limiter.
Old Jul 26, 2006 | 11:00 PM
trbopooh's Avatar
trbopooh
can you give more specifics??? sc setup? tuned or untuned?
Old Jul 26, 2006 | 11:07 PM
mikeyboy's Avatar
mikeyboy
well, pretty much untuned. I'm running the luxury motorworks FMU. its at 100% duty cycle at 8lbs of boost, which is usually where i'm at at WOT(7.9 to be exact)
Old Jul 26, 2006 | 11:10 PM
trbopooh's Avatar
trbopooh
hmmm...do you hear any strange noises? do you have a wideband? i'm unfamiliar with lmw's setup. could it be bogging??? i think the member mikal has the lmw sc. try pm'ing him. also try calling steve at lmw to see if he can better diagnose your problem.
Old Jul 26, 2006 | 11:12 PM
mikeyboy's Avatar
mikeyboy
Na, I don't have a wideband. What do you think it could be. I hope it's not compression issues? You think its an internal engine issue or an external issue
Old Jul 26, 2006 | 11:15 PM
trbopooh's Avatar
trbopooh
how long have you had this setup? did these problems just start recently? who did your tuning? try to pm mikal or lxogood to see if they can help.
Old Jul 26, 2006 | 11:20 PM
mikal's Avatar
mikal
Originally Posted by mikeyboy
well, pretty much tuned. I'm running the luxury motorworks FMU. its at 100% duty cycle at 8lbs of boost, which is usually where i'm at at WOT(7.9 to be exact)
why are you at 100% duty cycle
who tuned it for you?
Old Jul 27, 2006 | 07:04 AM
mikeyboy's Avatar
mikeyboy
The set-up is pretty fresh, i did install it like a year ago, but the car has been in the body shop for about a year. The set-up probably has about 20 miles on it at the most before today's meet. I coulda sworn when i was talking to steve he said i'm suppose to setup the e-manage according to how much boost i'm running? I'm maxing out at about 8lb's of boost. These problem's started today for the first time, never had this issue before with the set-up.
Old Jul 27, 2006 | 09:18 AM
mikal's Avatar
mikal
Your injectors might have been toasted. Running injectors at 100% duty cycle will burn them up.
Were you using a wideband to tune?
Old Jul 27, 2006 | 11:06 AM
Dx3's Avatar
Dx3
When you pass the 4800rpm mark do you start getting power back?? Sounds dumb but I had problems with belt slippage at a certain rpm.
Jonny
Old Jul 27, 2006 | 11:21 AM
mikal's Avatar
mikal
Jonny
He just edited his post above. Looks like he's been boosting without tuning it.
You need to get somebody to tune it for you. The "put put put put put" you hear might be detonation (pre ignition and can cause serious damage). Please be more careful. You need to find somebody that can tune it for you with a wideband.
Also, you might need to get somebody to check those injectors. 100% cycle is not good on the injectors.
Old Jul 27, 2006 | 01:04 PM
mikeyboy's Avatar
mikeyboy
I edited right away, i didnt change anything in the post, i just added.
Quick update:
I removed the supercharger belt and removed one of the intercooler pipes and the car runs perfect. I own a mechanic shop, and the injectors are fine. What do you guys have your e-manage set at?
Old Jul 27, 2006 | 01:06 PM
mikeyboy's Avatar
mikeyboy
Jonny
Hmmm....not exactly, but when i shift and let go of the gas at 4800 RPM's i hear the BOV, RPM's jump to about 4900rpm's.
Old Jul 27, 2006 | 01:10 PM
Rising_Sun's Avatar
Rising_Sun
Maybe what you hear is not the Blow off valve. It may be compressor surge and your BOV isn't working properly. That would make your RPM jump.
Old Jul 27, 2006 | 01:11 PM
mikeyboy's Avatar
mikeyboy
Another thing,
Since we're all thinking that i'm running too rich, why would i be pre-detonating?
