Problem with my supercharger/engine.
Old Jul 30, 2006 | 05:57 PM
  #31
JPI Racing's Avatar
JPI Racing
If you are running 6 psi the booster pump isn't needed. Get a scanner and check out your Long term fuel trim. Make sure it doesn't go past 10% .
JPI
Old Jul 31, 2006 | 05:55 AM
  #32
GILLEXUS's Avatar
GILLEXUS
JPI
Are you saying that a 6psi the stock ECU and injectors can handle it.?
Old Jul 31, 2006 | 10:26 AM
  #33
trbopooh's Avatar
trbopooh
nope. you need to run 310 injectors. i've already asked rod millen.
Old Jul 31, 2006 | 11:27 AM
  #34
JPI Racing's Avatar
JPI Racing
You don't need to when you are running the booster pump. What booster pump does is raising fuel pressure. Very similiar set up compare to PCS unit.
JPI
Old Jul 31, 2006 | 12:12 PM
  #35
GILLEXUS's Avatar
GILLEXUS
JPI,
I see what you mean. If he is using a booster pump no larger injectors needed but if he not running a booster pump and has stock injectors will the stock ECU and injectors handle 6psi??
How much can you raise the fuel pressure via a booster pump before it wears out or over works your injectors?? 40%?
trbopooh,
your talking about 2 systems. The S/C kit that Rod Millen sold they sold w/ 310 injectors to handle the fuel issue. The LMS S/C uses a booster pump to deal w/ the fuel issue I believe that is the one mikeyboy has.
Old Jul 31, 2006 | 12:21 PM
  #36
JPI Racing's Avatar
JPI Racing
I don't think we will have any issue at 6 psi at with stock injectors. We had to lean the 310'cc out quite a bit because it was funny very rich at top end. Otherwise the stock computer doesn't like that Long fuel trim going more than - + 10 %. That is the rule of thumb to tune these things.
JPI
Old Jul 31, 2006 | 12:28 PM
  #37
trbopooh's Avatar
trbopooh
Originally Posted by GILLEXUS
trbopooh,
which one are we discussing??? your v8 right??? haven't seen a sc'd v8 run only booster pump or fpr only. please correct me if i'm wrong.
Old Jul 31, 2006 | 12:29 PM
  #38
trbopooh's Avatar
trbopooh
JPI
thanks jpi. that's good info to know.
Old Jul 31, 2006 | 12:39 PM
  #39
GILLEXUS's Avatar
GILLEXUS
I thought your comment about 310 injectors was refering to mikeyboy's GS300. I was talking about his GS3 needing a booster pump or not w/ stock set-up
Sorry for any confusion.
Sounds like mikeyboy has a booster pump w/ his set-up and is using LMS's I-manage to conrol it.
Old Jul 31, 2006 | 12:45 PM
  #40
trbopooh's Avatar
trbopooh
nope. i know he has a gs3 running lms sc. i thought we were changing gears and talking about the gs4xx when you chimed in. didn't want to get people confused with different setups for the gs3 and gs4xx.
Old Jul 31, 2006 | 01:34 PM
  #41
GILLEXUS's Avatar
GILLEXUS
No problem.
Old Jul 31, 2006 | 01:51 PM
  #42
trbopooh's Avatar
trbopooh
Old Jul 31, 2006 | 02:02 PM
  #43
GILLEXUS's Avatar
GILLEXUS
JPI,
I'm curious to know how much can you raise the fuel pressure via a booster pump before has any adverse affect on your injectors. Say for example ,if your stock injector are at 45psi would it be safe to safe to increase it by 50% to 67psi w/o over working the injectors??
Old Oct 2, 2006 | 07:37 PM
  #44
GILLEXUS's Avatar
GILLEXUS
Originally Posted by mikeyboy
Well today my car was giving me a pretty big problem 2GS3. The car at around 4800rpm's +- 5lb's of boost the car begins to like put, put, put, put rapidly, continuously, and powerless. The putting starts around 4k rpms and continues to about 4800 where it really doesn't give out any power, although i am boosting. It's almost identical to me hitting the rev limiter.
Did you ever get your Lex running right? what was the problem?
Old Oct 3, 2006 | 06:11 AM
  #45
JPI Racing's Avatar
JPI Racing
I would take a look at the long fuel trim. We all have to remember, Fuel trim is very very important when tuning these thing. Are you running the SAFC?
JPI
