o2 sensors
cel came on, went to dealer they said it was bank1 slot2 something of that nature. then went to a friend that works in firestone. said the car has 4sensors or 3. he wasnt to sure off the top of head. so asking how many, and where r they located? how hard are they to change out? Has anyone changed them out b4 and posted it on the site? thanks in advance.
CENTER: located on the exhaust manifold, for spark plug #s 1/2/3. It's also referred to as the #1 sensor.
FRONT: located on the exhaust manifold, for spark plug #s 1/2/3. It's also referred to as the #2 sensor.
EXHAUST PIPE: as it name says, it's located on the exhaust pipe.
REAR: located on the exhaust manifold, for spark plug #s 4/5/6.
All of them are four-wire sensors, with slightly different plug set-ups and varying wire lengths. Of note, there is a difference in the "exhaust pipe" and "rear" sensors for models produced up to July 99 vs. August 99 and up.
I've changed oxygen sensors on my older cars (non-Lexus), which wasn't too difficult provided you have the right tools to do the job. An oxygen sensor socket tool comes in handy. Hope this helps. Good luck!
Originally Posted by SportyStar
For a 2000 GS300, you need to picture the inline 6 engine from front (radiator side) to rear (firewall side). With this in mind, there are a total of FOUR sensors at the following locations:
i have the 99300, is this the same set up as the 2k? do anyone know where to get the 02sensors on line, for a decent price? Looked around, and cant fine them for under 125. any help is greatly appreciated. thanks
Yes, same set-up for 99 vs. 2000 models. However, different sensors for the exhaust pipe and rear sensors (prod. date up to 7/99 vs 8/99 and later).
akswagga
Jun 6, 2015 08:47 PM
sabbates
GS - 1st Gen (1993-1997)
Mar 13, 2014 07:04 PM
Horsepwr
Aug 11, 2010 02:46 PM
