Strange LSD Question
Old Jan 19, 2005 | 03:55 PM
redgs4's Avatar
redgs4
Question Swapping Ring Gear on LSD
I currently have an ATS Carbon LSD which is a clutch type installed in the stock pumkin.
I have a supra 3.76 LSD sitting in my garage which I was planning on installing soon.
Would it be possible to swap the ring gear off the supra pumpkin - thus creating a 3.76 ATS LSD? Not sure I would do it even if possible but the concept interests me. The ATS is smooth and the overall unit is lighter than the gear heavy torsen unit.
Old Jan 20, 2005 | 03:38 PM
FutureGS400's Avatar
FutureGS400
I have done a few gear swaps in the past on 4x4 trucks, and normally the ring and pinion gears are swapped, not just the ring gear. Not positive if this is always the case though. The two pumpkins are slightly different, but it looks as if the Supra gear set would fit. Here's a pic of the two side by side.
BTW, have you actually weighed the two units? I did and as I recall, the weight difference was not that much. I think I posted the weights on a past thread.
EDIT: Just found the old thread-stock diff weighs 86 lbs., Supra LSD weighs 93.5 The additional weight is more due to the bigger housing than the stock GS, although the Torsen gears probably do add a few pounds too.
Hope this helps...
Old Jan 20, 2005 | 10:42 PM
redgs4's Avatar
redgs4
I have only weighed the Supra LSD thus far - it hit 100 lbs on the mark on my scale. Probably all the rust and other crap - the unit I have is "pre-owned". When I swap I'll get the weight of the stock unit. Just playing around with ideas. I'm sure I'll end up installing the supra unit as-is, mainly to compare and contrast the difference between the two. Thanks.
Old Jan 20, 2005 | 10:45 PM
RMMGS4's Avatar
RMMGS4
Northern California Regional Officer
Dibs on your ATS Red!
Changes a comin !
Old Jan 20, 2005 | 11:05 PM
redgs4's Avatar
redgs4
Changes a comin !
Whatever could you be talking about?
Old Jan 20, 2005 | 11:15 PM
rominl's Avatar
rominl
exclusive matchup
Changes a comin !
and dips on yours
Old Jan 21, 2005 | 10:33 AM
FutureGS400
Mine was weighed without lube in it, so that accounts for some of the weight difference. You're gonna love the lower gears, the Torsen may take some getting used to.
Old Jan 21, 2005 | 03:01 PM
rominl's Avatar
rominl
exclusive matchup
i know when red weighed his, there was no fluid inside too
Old Jan 21, 2005 | 04:27 PM
FutureGS400
His probably has 6.5 lbs of sludge and rust inside! (Hope not)
Old Jan 21, 2005 | 05:41 PM
rominl's Avatar
rominl
exclusive matchup
hahhaa i am laughing so hard. i saw that lsd unit, there were some dirt around, but not sure about 6.5lb
Old Jan 21, 2005 | 11:43 PM
redgs4's Avatar
redgs4
All this talk about rust & sludge has given me an idea for my next project. I was going to just slap that puppy on the car - it's not like anyone is gonna see it. But looking at FutureGS400's nicely cleaned diffs has inspired me to clean mine off and maybe give it a coat of paint.
Old Jan 24, 2005 | 03:47 AM
rominl's Avatar
rominl
exclusive matchup
come on now, that's waste of time i mean, when was the last time you clean the bottom of the car
Old Jan 24, 2005 | 08:45 PM
redgs4's Avatar
redgs4
When was the last time I needed to? That LSD is really gunked up!
Old Jan 24, 2005 | 09:39 PM
rominl's Avatar
rominl
exclusive matchup
mine was all dirty when i got it too, but who cares. as long as it works fine
Ke0
IS - 1st Gen (2001-2005)
Jan 16, 2012 09:56 PM
SC400DRFT
Sep 16, 2006 06:05 AM
clubaddict
Aug 25, 2005 05:39 AM
LasVegasGS
Performance
21
Jul 28, 2005 07:42 PM
TLW
Performance
34
Mar 21, 2005 09:33 AM
