check engine light problems
Old Oct 13, 2004 | 09:22 PM
gsowner99's Avatar
gsowner99
Default check engine light problems
Ok, so here's the scenario...
I have a 1999 GS 400 with 107 000 miles. A few months ago, the engine would stall out as I come to a complete stop and try to gas up to go again. I would have to shut the engine off and start everything back up again. This has happened several times. I called up the dealership and they said it was probably because of the gas. I have never put in anything other than 94 octane.
Recently, as I start the engine up again, I would feel the car "jolt" and I wouldn't be able to get the transmission to go past what feels like 1st gear. I don't really know what gear it's in but as I am stepping on the accelerator, the car moves, but very slowly and there is definitely no acceleration. I would have to stop the car completely for about 5 minutes and start her up again. When the car finally behaves normally, the check engine light and both the VSC on and VSC off lights are on. Weird. At least the car can move and I can stop blocking traffic.
When I bring the car to a complete stop, sometimes I feel the engine wanting to stall out. The rpm seems to be lower than usual (about 400 -600).
I have brought the car to the local Lexus dealership where they have run a 2.5 hour diagnostic to find the problem. They tell me that they can't find any problems with the car. The technicians tell me that not even the engine codes stored in the computer indicate any problems. Can this be true? Help!!!!
Any thoughts would be appreciated by this newbie. Thanks in advance.
Old Oct 14, 2004 | 07:26 AM
Fisher503's Avatar
Fisher503
My friend is having the exact same problem with his Firebird. It is his catalytic convertors. It could also be your mass air sensor but really sounds like a bad cat
Old Nov 1, 2004 | 12:23 PM
DXGS400's Avatar
DXGS400
I would check your CATs, and your O2 sensors as well. I can't believe you got the Check Engine light on and dealer can't find any codes. I would take to another dealer.
My girlfriend had a 91 Subaru before, when stepped on the gas, it will move so slow, then, it will pick up the speed after like 5 seconds. We took to the dealer, and guess what? The timing was way off. They readjusted the timing belt, and everything run great after that.
good luck.
chuckli
Performance
20
Mar 14, 2018 02:23 AM
Ladoo1980
IS - 1st Gen (2001-2005)
Apr 23, 2017 10:28 AM
Joyride250
Apr 24, 2011 07:10 PM
Iszy250
Maintenance
May 20, 2010 01:12 AM
shawnst
RX - 1st Gen (1999-2003)
Oct 10, 2007 06:03 AM
