d3 tune, I lost custom and sport+ mode
They provided me the diagram to connect the bricked ECU on the bench with the Tactrix device, and using their software to do the recovery procedure.
See pics below from when I removed the ECU from the engine bay - all needed was to first remove the car battery for safety and then unscrew the plastic cap and then the ECU itself. I think they were 12mm bolts.
Then helped by the provided diagram and some minor skills, I have connected the ECU to the Tactrix device + a 12Volts source + the laptop. You can see below the ECU on my bench and the connections (you need their diagram specific for your ECU!)
Then I have used the software to do the recovery (nevermind the last highlighted in red alert message, - software gimmick - all was good)
And afterwards, I went back to the car with the restored ECU, started the car to check if it was all good, and finally I have tuned the car as I wanted from their tune options.
Please note that I have the 200t - 2.0 Turbo engine. In your case the diagram and even the ECU location may be different.
Regarding my opinion on the d3 tune: I have used a piggyback tune before this, and I can say that the low-end on the D3 is just a bit less agressive than it used to be on the piggyback device - HOWEVER once the revs go higher, it is a lot better and it holds the boost on the turbo until redline. The transmission is in tune with the whole package - I am very happy with the tune and also I love the fact that I can keep it a notch down when in Normal mode, and then unleash the beast in Sport mode - which should be the way to truly and fully enjoy this tune.
Let us know how and when you solved your issue.
Back on topic: Try re-installing the tune file.
So, once again the post above is spot-on, I think you should:
1. Re-install the tune, but please make sure your car is stock, as in, all fuses are in their place, so that the software would know what capabilities your car system has.
2. At any stage, should you encounter any issues, just call D3. I know I did and got every bit of help I needed. D3 Performance phone number: (832) 953-5431, Monday-Friday 9:00 AM - 5:00 PM CST
Also, at any step, just remember that it is really hard to break your ECU, and if it becomes bricked then you have OPTIONS! As per above posts, so nothing is lost, the world does not end!
What Does The Term “Bricked Computer” Mean?
The terms “brick” and “bricked” can apply to a computer or hardware component that has experienced a poor upgrade and/or change, most typically a firmware update change, and that as a result is no longer in operation for the original nor, new purpose. The equipment being updated would fail to work and perform the intended task, for instance, if someone performed the firmware update or programed changes erroneously or failed to allow it to conclude effectively.I already think about calling directly D3 but english is not my main language so that will be hard to communicate with someone by speaking. Its a lot more easier to me to talk by message
I already tried to uninstall/reinstall tune, sport+ and custom always missing
Its a pretty good call about the fuse, but D3 call me in the past, its impossible to flash the wrong car because of the VIN number. So its supposed to be a tune for a 2018 is350 AWD. And all is350 from this year have AVS no? So even without the fuse, its supposed to flash like it was a is350 with AVS right?
I send a message about this to D3 and let see what he will say
They reply me a couple of times, to reset de ECU and sport+ will be back. But I said I did it but my issue still. So now I reply to him about the fuse. Waiting for the answer
I did some test, I tune back to stock without the fuse, no sport+(that was not the case the 1st time I did it). So ECU check the fuse, to know if its a car with AVS or not(after each reset). So I think, when I flashed the tune for the 1st time(no reset), ECU remembered that I have a AVS system, even without the fuse. So its why I keep sport+ when I flashed back to stock the 1st time. After each ECU reset, ECU forget I have it(stock or tuned). So I need to put back my fuse and flash a tune to get sport+ back(flash to stock or stock->tuned)
So I put back my fuse, flashed the tune and now all is okay!
Thx for the help guys!
I flashed stock->tuned with fuse, put on sport+ mode, removed the fuse and now I have sport+ everyime I start the car, even without the fuse
