No spark no crank position sensor???
Old 11-01-11, 06:06 PM
Dustindude
Dustindude's Avatar
Question No spark no crank position sensor???
I have 94 sc300 GTE non vvti. It isn't getting spark or fuel. I can't find the crankshaft position sensor. It's not in the front of the block by the water pump/crank pully. Where could it be? Does it even have one? Could it be in the distributor or bell housing?
Old 11-01-11, 07:39 PM
sc300max
sc300max's Avatar
The actual sensor is under the lower timing cover, wires come out somewhere around the alternator more or less behind it. It is a plug with two wires. Make sure you have power everywhere first before you think its the sensor, check power on coils, injectors etc... Hope this helps.
Old 11-03-11, 01:27 PM
2jznosht
2jznosht's Avatar
your car gets cam/crank info from the distributor. While the dist may have gone bad it's probably your ecu that failed. Ask me how I learned that lesson
gr8fulRed
05-20-18 11:00 AM
nayborbob
ES - 5th Gen (2007-2012)
20
01-06-18 10:48 AM
Jamil518
03-22-16 03:14 PM
Sc375
12-14-13 07:01 PM
Zinik
12-10-12 07:17 PM
Quick Reply: No spark no crank position sensor???
