My first 25 NX problem
Today when I pulled the hood release handle/lever to open the hood, something popped and the hood didn't release.
I found that the lead lug on the cable end popped out of it's socket on the handle.
I just pulled on the cable to open the hood, no problem.
Has anyone ever pulled that whole panel off that houses the trunk release handle ?
I'd like to take a closer look to see what happened - photos below
Last edited by Amigo; Jan 29, 2025 at 06:44 PM. Reason: wrong word "trunk" should be "hood"
Definitely bring it back to dealer and have them go through the whole hood latch setup to see why it broke off. It's under warranty still I'm sure.
If my memory serves me correctly, the pull tab should be able to go through it's full stroke, and by then the pull handle will almost be at a horizontal position and basically out of travel, and still not see any resistance from the cable enough to pull it out like that.
Curious how the handle snapped. is there resistance at the hood side?
you'd think in 2025, it would be electronically actuated. you'd delete 6 feet of steel cable. instead you can have 1 feet of cable for cases you need a manual pull.
I’m not sure but have two guesses: I may have pulled the handle too enthusiastically, or it may have been weakened at installation, it looks like the cable needs to be twisted a lot to get into position.
omgswifty
Nov 17, 2008 02:56 PM
