Has anyone figured out a way to convert or utilize the trunk to carry the Modern Spare on all NXs except 250? Did you buy the full kit with the tools, jack and case ? If so, did you store the tools and jack under the deck.
Did you add tie-down straps to secure the tire?
A true spare is needed, in case of tire emergencies.
There are lengthy threads already on the topic with a wealth of information. User Amigo is the only one who fabricated a solution to properly secure it down. I may look into some kind of straps when I have some time.
Thanks, but these are all for NX 250 or NX 350 without battery under cargo cover. Has someone mover the 12 V battery on the 350h ?
YMMV,
MidCow3
I think the problem is getting around the “battery in the trunk”. My 350 is under the hood. Could the battery in the trunk be relocated in the trunk to make room for the spare ?
I bought the spare only, l have a small hydraulic jack, 18” breaker bar, small 12v air pump, tire plug kit & jumper cables - it all fits under the spare and tire support shelf. I would take photo to show what’s under the cover if interest.
YMMV,
MidCow3
Since you have the Modern Spare already, have you tried removing all of the storage bins and trim pieces and see if the tire can even fit in the bare trunk? Even if at an angle. If that's not even possible, there is really nothing to discuss in terms of fabricating a way to make it all fit under the trunk lid.
Not possible unless the battery can be relocated easily on 350h
