NX - 2nd Gen (2022-current)
Lighting
Old Dec 10, 2023 | 08:28 AM
iiPanda's Avatar
iiPanda
9th Gear
Default Lighting
Hello, does anybody know if the fog lamp for the 22 NX350(Luxury) is H11 plug or its a different plug?
Old Dec 11, 2023 | 08:31 AM
toyotaman7's Avatar
toyotaman7
LED lights with custom connectors
Old Dec 11, 2023 | 08:33 AM
iiPanda's Avatar
iiPanda
9th Gear
Got it. Is there any ways I can change to brighter bulbs? I’ve tried looking for the connector size but no way I can find it.
Old Dec 11, 2023 | 08:36 AM
toyotaman7's Avatar
toyotaman7
There are no bulbs. Its is a complete LED light assembly.
Old Dec 11, 2023 | 08:40 AM
iiPanda's Avatar
iiPanda
9th Gear
Got it, so it’s the same with the rear light assembly, I thought the rear turn signal are bulbs are well. After I took the assembly out it’s just a power cord with the LED panel. So in another word there’s no bulbs that could be change out beside the front turn signal.
Old Dec 11, 2023 | 08:48 AM
toyotaman7's Avatar
toyotaman7
With base headlights, yes. Work triple beams, everything is LEDs.
I hope they last the life of the car. Will be REALLY expensive to replay burned LEDs.
Old Dec 11, 2023 | 08:53 AM
iiPanda's Avatar
iiPanda
9th Gear
I’ve checked on some Lexus website that the rear assembly is around 430-480$ a piece. So yes they are quite expensive. And also with the door dome light, could I possible install them myself, do they already have a power cord behind the door panel?
Old May 22, 2024 | 12:19 AM
JUMPARK's Avatar
JUMPARK
Default The led fog light is replaceable
I have the switchback LED replacement but there’s a screw that requires a specialty screw bit that’s holding it together once I bipass that I would be able to replace my LED fog.
Old May 22, 2024 | 06:47 AM
Zlobix's Avatar
Zlobix
In our NX, you can replace the LED bulbs in the front fog lights and rear reverse lights.I tried to replace them but failed.The screw shown in the last photo is on each lamp and I could not unscrew it in the rear lights.When I broke the standard lamp, it turned out that I had ordered the diode lamps from Aliexpress incorrectly.I ordered diode lamps from Toyota, but they do not fit the Lexus at all, although they are very similar.It is necessary to order diode lamps specifically for Lexus.In addition, to install them, you will have to contact an authorized dealer or service station, where there is a special tool for this screw.
Old May 22, 2024 | 07:11 AM
Zlobix's Avatar
Zlobix
Please note that to replace the diode lamp in the fog lights, you will need to lift the car on a lift and remove the plastic protection, unscrew the screw and replace the diode lamps.Here is an example of the correct diode lamps for Lexus. https://sl.aliexpress.ru/p?key=4k7gs1L
Old May 22, 2024 | 12:39 PM
JUMPARK's Avatar
JUMPARK
That’s the one I have. I just need to remove that screw. Does anyone know what that screw bit is called?
Old May 22, 2024 | 12:44 PM
JUMPARK's Avatar
JUMPARK
I was able to plug in the new LED to see that it works! I just need to find that damn tool to finish the installation
Old May 22, 2024 | 02:09 PM
midcow3's Avatar
midcow3
Lightbulb
This might help, different car model but upgrade of LED lights : https://www.clublexus.com/forums/gx-...to_threadtools
YMMV,
MidCow3
Old May 23, 2024 | 03:08 AM
JUMPARK's Avatar
JUMPARK
YMMV,
MidCow3
the pictures included did have a similar screw but seemed like he didn’t need to remove that part so he never had a tool to unscrew that part of the fog light
corcorand
UX Models (2019-present)
Nov 23, 2020 09:00 AM
kitsune
IS F (2008-2014)
Oct 5, 2016 08:42 AM
ChronoJ1
SC400 / 300 Classifieds
Jul 28, 2007 07:21 AM
ChronoJ1
Dec 11, 2003 05:03 AM
