NX - 2nd Gen (2022-current)
Subwoofer
Old Sep 23, 2025 | 08:27 AM
  #496
GeoM's Avatar
GeoM
Default ML system test sound.
Shoot with s25ultra but still it can't reproduce real sound.it has plenty of bass,using flash drive,level 50,no distortion if i increase a sound
Old Sep 24, 2025 | 08:51 AM
  #497
avibobby90's Avatar
avibobby90
5th Gear
Originally Posted by tundotcom
Installed my Infinity Reference REF-3032CFX speakers today. Thanks to @Droid13 @SgtLip @AtomicLexus and others for their help. Getting the speaker grilles off was the hardest part for me. The passenger side one in particular is hindered by the A pillar cover, so I really had to yank it out. I ended up leaving a mark on the A pillar fabric on both sides but I don't care too much about that.
The rest of the installation was pretty easy. All the advice was spot on. 10mm combination wrench to crack the screws loose and carefully remove by hand. Metra 72-8109 is indeed the correct cable. The black and white ends are different sizes so there should be no mistaking where to clip them onto the speaker end. Inserting the screws at a 45 degree angle at first and then slowly tightening them down worked like a charm.
If you're a complete newbie like me, you can definitely do it on your own with the information in this thread. The speakers sound much better than the OEM Pioneer speakers but as mentioned before, the weak bass is definitely more noticeable now.
The last part for the subwoofer amp install from AliExpress arrives today, but now I need to wait for one of you guys to take pics of the entire process before I attempt it on my own.
edit: everything has arrived. Anything I am missing?
were you able to get this setup done? If so, can you please share me the pics of the setup.
Old Nov 26, 2025 | 07:20 PM
  #498
MoNX350's Avatar
MoNX350
Originally Posted by hexpletive
So far it sounds great.
It's only been in for a couple days so I'm still running through a lot of my normal music listening for resonance issues. I haven't really found anything that is annoyingly rattling around yet.
I did lay some sound deadener directly under the sub but I didn't go crazy with it. I doubt it has much impact in this car with the factory deadener/sound absorbing material it already has. But I was already in there anyways and had some deadener material.
I'm running a pretty conversative gain setting on the amp. I originally set it just below clipping with a 40hz -5db signal at 50 volume on the head unit and it was too much for the rest of the system and was overwhelming everything else. And big boomy bass isn't really what I go for these days.
I thought I might try it up firing if I wasn't getting enough bass response down firing, but I don't think I'll be doing that anymore.
The trunk liner still has the hook on the right side holding it down. With the rear seats in the recline position those also hold it down pretty well. I have to put them up to the normal position to unclip it from the storage bin.
That amp looks like it should be fine for that sub.
Kicker 49L7TDF102
2-ohm total impedance
power handling: 500 watts RMS (1000 watts peak power)
Kicker 51LX850.1
500 watts RMS x 1 at 2 ohms
You don't technically need a LOC because the amp has high level inputs and signal sensing turn on. But some LOC's like the 47KEYLOC have additional features for more tuning options.
Completed the install over the weekend. Love the upgrade, what a difference!!
Old Nov 27, 2025 | 11:04 AM
  #499
1Priest's Avatar
1Priest
Great pictures and thank you for sharing them. I have to deaden my rear door on my NX as well and I'm wondering, did adding the sound treatment to the rear door like you did add additional weight and in any way affect it opening and closing? Once again thank you for sharing these pictures my friend.
Old Nov 27, 2025 | 11:22 AM
  #500
MoNX350's Avatar
MoNX350
Appreciate the feedback!! I have not noticed any difference in opening and closing the hatch. Works just fine from my experience. Fairly easy to take everything apart just get trim tools and go slow. Lots of nooks and crannies you can fit some material in. The more the better. inside the cabin sounds great and controlled now.
Happy Thanksgiving!!
Old Nov 27, 2025 | 11:45 AM
  #501
1Priest's Avatar
1Priest
Excellent! 💪 Appreciate your response and initial post and thank you so much my friend. Wishing you and your family a very Happy Thanksgiving! 😀
Old Jan 4, 2026 | 09:01 PM
  #502
davismattg's Avatar
davismattg
3rd Gear
Originally Posted by tbartman67
I will say, IMO, I didn't like your placement for the sub because what if you want to put a suitcase there that is a little long, and losing the 3-4" means you can't close the back door? Or if you want to lay both seats flat to load a piece of plywood, or stack a ton of boxes? My placement, it's completely out of the way. Here's my install:
I didn't have to tear anything apart, and can return things to the way they were in seconds.
First, I undid the connector that ran the speaker wires to the old sub. I figured the old sub was useless once I got the new one in. The Metra connector then attaches to the speaker wires coming from the front of the car. Here you see the wires from the amp and the Metra adapter in the middle of the photo and the old connector to the old sub dangling just to the left of that:
I cut off the ends of the Metra adapter and stripped a little bare wire, and Kicker told me to connect the (+) to the (+) of both the left and right input, and same for the (-) wires. So here you have the white wire from the Metra going to both the white and grey wires of the Kicker harness, and you have the black wire from the Metra going to both the white/black and grey/black wires on the Kicker harness.
By setting the Kicker HS10 to DC switching (instead of 12V), the signal from the amplifier is enough to turn the sub on and off, and there's no need to use the cigarette lighter or hook anything else up there.
Then for the power - the car battery is right there. The Kicker comes with a short red wire with a fuse that needs to be near the battery, so put the ring terminal on that and connect it to the screw terminal Lexus put on top of the battery already (you'll need an M8-1.25 nut), then connect the other end of the short red wire to the red wire on the Kicker harness (I cut that shorter, but you don't need to):
Then the same for the Kicker harness black power wire to the negative terminal of the battery:
All done! If I need to reverse things, I take two nuts off the battery; I unclip the Metra connector and hook the connector from the amp back up to the old sub, and I'm done. Again, I didn't use any other power source for the switching on/off of the sub, and I didn't use the additional bass control **** that came with the sub. It's all under the floor deck and invisible.
Has anyone tried this with the Mark Levinson system? I have the ML in my NX and followed these instructions to a T and the install was smooth. However I can’t get the sub to turn on with the auto-on setting set to DC. Even when I have the bass turned to all the way in the audio settings, I only get a red power LED when there is noticeable sub in the song. When there’s no bass in the song, I get no power LED. I confirmed 14V at the HS10 coming directly from the battery.
Check the attached video, where you can see what I’m talking about. In the video I actually got one or two momentary blue power LED readings where the sub actually kicked on. Seems like the input voltage signal isn’t high enough.
EDIT: After some more debugging, it appears the auto turn-on isn't sensitive enough to the input signal. When I tried a sub-frequency test tone, and cranked the volume up 3/4 of the way in the car, the sub triggered on and played the note. But as soon as I decreased the volume, the sub shut off again.
File Type: mov
Old May 5, 2026 | 09:53 AM
  #503
LilyP's Avatar
LilyP
3rd Gear
Hey! I know this is an old thread. I've read through it in detail and also some other threads related to the sub par audio on the NX. Recently I replaced my dash speakers with the JL Audio C2-400X and it was a pretty nice improvement but, like was mentioned in the forum, after getting used to the new speakers up front, the lack of bass became even more noticeable (I tried to listen to an old Beastie Boys album and it didn't sound anywhere near right) so I'm planning to upgrade the subwoofer in the near future. I have the 350H so everything is close together which makes for a more simple install. I am fairly sure I can manage myself but I have a friend who is more experienced with making the wire connections so I thought it might be smart to have him help me. My gameplan is to buy the metra connector that will connect to the existing Sub connector so that I can easily restore to factory. For kicks I did get a quote to install the sub and was quoted $408 and that was with me supplying the sub and the metra connector which is kind of crazy!
Quality is more important than super loud volume for me and I'm considering the Audison Prima APBX AS2. Have any of you all installed that sub? I saw one installation on another forum and it fits in the trunk cargo tray beneath the floor like the kicker but just takes up a little more space in that area. I had considered the Rockford Fosgate PS-8 as well but it seems like there's some quality issues based on reviews and some people have had early failure rates with more than one replacement.
If anyone still reads and responds to this, I have a few questions:
Did you anyone need to go to a car audio place for sound tuning after you installed your sub and speakers or were you able to get it adjusted to your liking on your own? I don't want to install or use the remote for the sub. I just want Set it and Forget it.
Did you all replace that center dash speaker? I left mine alone for the time being but wondered if I'll want to pick up another JL speaker from ebay to match the ones that I bought. I have turned off the surround sound setting on the car for now and it improved the sound of the front dash speakers but I'm wondering if I replace the center one, if turning the surround sound back on will sound better than it does with the original factory speaker in or if that has no bearing?
I hope that upgrading the sub works out for me sound-wise and I don't have to switch out the door speakers as well. I am really not that picky and most cars I've had in the past sound was fine. My last car was a Honda Civic with the factory Bose so maybe I got spoiled with that one but I swear this NX may be worse than my old Elantra.
Old May 7, 2026 | 10:59 AM
  #504
Lexicon1's Avatar
Lexicon1
1) yes , many have replaced the center speaker w the same as both dash speakers
2) its your call, if heavy bass is your preference....add a complete sub/amp set up
3) Several have just added a simple small amp to power the stock 8" sub speaker... several have gone w Fosi, I went w Taramps w a fuse , it definitely adds to the lower end and is quite satisfactory compared to the same sub speaker powered by the OEM amp.... search tool on the site is your friend.....
Keep us posted on your findings
MrJason
GX - 1st Gen (2003-2009)
29
May 24, 2019 03:57 PM
Darthspeed
May 17, 2012 02:49 AM
Blk03GS430
Feb 5, 2012 08:11 PM
Kuki_350
Oct 12, 2006 07:19 AM
Overtaxed
Jul 28, 2001 01:12 PM
