NX - 1st Gen (2015-2021)
ATF Drain//Refill
Old Apr 4, 2020 | 05:02 PM
chuyrobles's Avatar
chuyrobles
Default ATF Drain//Refill
Where is the ATF fill plug on these transmissions and what tool(s) do I need? It's for my sister's NX200t; she going to bring it to my house in a couple of weeks and I want to be prepared as much as possible. Didn't find a youtube DIY video for this model Lexus. I'm going to also replace the plugs but youtube videos show that to be straight forward.
Old Apr 4, 2020 | 08:29 PM
chezgk's Avatar
chezgk
The following files would probably be of use to you. As the transmission is the same as 3.5 Toyota/Lexus/Lotus transverse 6A/Ts, this applies to the other vehicles in your signature as well.
Old Apr 4, 2020 | 11:43 PM
chuyrobles's Avatar
chuyrobles
Excellent. Thanks. Refill bolt appears to be in same location as for the ES350. Good to know about the ATF temp range. I'm going to measure how much comes out and replace same amount, but to know about the temp range if I mess it up. I presume it's the same temps for the RX350? Thanks again.
Old Apr 5, 2020 | 05:16 AM
chezgk's Avatar
chezgk
You're welcome! I wasn't able to download the files for the RX350 but would be surprised if they were any different. Heck, even the Quaife helical LSD for the 3.5 Lotus Evora IPS fits all of them. 😄
EDIT Oops you have the 8 speed RX350. Yes, that's definitely different.
Old Apr 6, 2020 | 08:39 AM
Danny200t's Avatar
Danny200t
At what mileage should this be done at? i’m at 51,000km right now and planning to change the transmission fluid. Does the rear differential fluid need to be changed as well?
Old Apr 8, 2020 | 02:34 PM
rmak's Avatar
rmak
Thanks for posting these. They are actually better than the ones for the U660 in the ES350.
Old Aug 23, 2020 | 08:32 AM
nexus86's Avatar
nexus86
Picked up a 2015 last week, performed the transmission fluid service this morning.
i was expecting a little more fluid to come out. Only got about 1.5 liters. Refilled with 1.75 liters, a little extra to ensure i have some to drain. I’ll keep doing this once a month until the fluid looks new.
if any one was thinking about doing it themselves, it was nearly as daunting as I thought it might have been.
only real special tool required is something to confirm you are between 104-113F to do drain the extra. I used an ELM327 paired to an android.
Old Aug 23, 2020 | 10:25 AM
jonnyyaa's Avatar
jonnyyaa
Id love to know too - im at 58000km!
Old Aug 23, 2020 | 10:27 AM
nexus86's Avatar
nexus86
given the cost of 2-3 jugs of fluid and no filter required. If you have to ask, you might as well do it. It can’t be done too soon. The fluid should look bright red. So if it isn’t that color, keep doing it until it is.
doggystyl
Hybrid Technology
60
Dec 15, 2025 05:17 PM
mcfancy
Jan 29, 2012 08:44 PM
Ryan300
RX - 1st Gen (1999-2003)
Jan 7, 2011 09:16 AM
deus85
Sep 5, 2007 10:08 PM
lexite
Maintenance
26
Jul 20, 2006 05:57 AM
