NX - 1st Gen (2015-2021)
Cargo net issue
Old Jan 2, 2016 | 03:32 AM
miop4000's Avatar
miop4000
Default Cargo net issue
The cargo net when attached to the suggested mounting points blocks the descent of the 2 cords that hold up the rear cargo cover. The result is that the cord doubles up on itself and jams in the rear door frame. To avoid this there are 2 metal rings on the rear pillar that you can connect the cargo net. You need 2 additional clips Similar to those on the base of the net to use these mounting points.
I am getting the impression that the accessories have not been very well thought out.
Old Jan 2, 2016 | 09:00 AM
Swacer's Avatar
Swacer
Think it might just be you, mine works great.
Old Jan 2, 2016 | 10:36 AM
jim256's Avatar
jim256
Thanks- had not noticed, but the round rubber "weights" do hit my net when it's attached to the upper "grocery hooks" and cause slack in the cords. Sometimes the cords fall across the rubber weather stripping into the outer channel, and other times fall within the cargo area. Thanks for finding this. I tried a small carabiner on the pillar tie-down points but it leaves a lot of vertical slack on the net and still can create the problem. I wonder if a heavier weight on the cords would help? Don't have a solution but the cords would get wet and grimy if they fall in the channel and you drive in a storm.
Old Jan 2, 2016 | 08:37 PM
Koetsu's Avatar
Koetsu
Mine does, too.
Old Jan 4, 2016 | 08:03 AM
philwojo's Avatar
philwojo
I have never had this problem, but I can see what you are saying at least. I haven't looked, but how easy would it be to put on a metal washer or 2 or 3 to the bottom of the cord to add weight to it to help this issue?
Old Jan 4, 2016 | 08:30 AM
jim256's Avatar
jim256
For my part, I'm first going to try getting a plastic clip to attach to the top of the net in lieu of the cord loop, then try hooking that to the cargo hooks instead of the grocery hooks. Your idea could work but it's easy for anything to get tangled in the net, and the net sits right under the current rubber weight.
About 50% of the time the cords fold into the car after the round soft rubber washer hits the net, about 50% across the rubber and into the channel. You need to be standing beside the car to even notice because of the dark glass. I expect this is a "universal Lexus" net because my ES300h had the same top loops and attached to its grocery hooks. The NX manual on page 440 appears to show the top fastened to the cargo hooks, not the grocery hooks, which is not feasible with the loops unless you tied them.
The only issue I have had with the NX--very minor.
Old Jan 7, 2016 | 08:49 PM
JediDon's Avatar
JediDon
I noticed this issue on mine too. I made a note of it on my Lexus survey. How can people not have this problem if they have the cover and cargo net installed? Those round rubber weights go straight into the cargo net. I'm not worried about the cords getting wet, but having moisture leakage in the rain if the seal integrity is reduced by the trapped cord.
Old Jan 7, 2016 | 11:16 PM
miop4000's Avatar
miop4000
Agree, inherently poor design. A minor problem that can cause major issues with water leaks. You simply don't get these type of problems with the level of engineering in a Merc for example.
And yes some people are just clueless.
Old Jan 8, 2016 | 03:51 AM
Swacer's Avatar
Swacer
No, you get a plethora of huge ones
Old Jan 8, 2016 | 11:58 AM
NXOwner's Avatar
NXOwner
From: Driving a UX Hybrid F-Sport! (in So California)
Agreed...especially the outboard models! Oops! You said "merc", so I assume Mercury marine engines for boats.
If, by "merc", you mean "MB" or "Mercedes", they have their collection of small issues, as well. Additionally, they have a surprisingly amount of larger issues after a few years, unlike Toyota/Lexus, Honda/Acura, etc.
Old Jan 8, 2016 | 12:12 PM
jim256's Avatar
jim256
Been there--and you don't need to go back to the dealer and wait for "parts sent for your specific car from Germany" when the (optional) cargo net has contact with a string.
Dadofruth
RX - 3rd Gen (2010-2015)
May 11, 2015 05:19 PM
tom_s
Jun 24, 2011 09:10 AM
jerryray
Mar 28, 2011 01:17 PM
