EFI Fuse
Old Jul 29, 2013 | 02:07 PM
Complexus's Avatar
Complexus
Default EFI Fuse
What's up, everyone...... I'm having an issue with my EFI fuse which is 30a and it keeps on popping. Can anyone help me with this problem. Thanks
Send solution to my inbox or post whichever.
Old Jul 29, 2013 | 03:03 PM
GS4_Fiend's Avatar
GS4_Fiend
Short to ground on power side. Tracing the short is gonna be difficult. Basically look for frayed wire along the way.
Old Jul 29, 2013 | 05:22 PM
BDSL's Avatar
BDSL
Isn't the EFI fuse 15amp?
Old Jul 30, 2013 | 10:43 PM
Complexus's Avatar
Complexus
It's a 30amp
Old Jul 31, 2013 | 11:52 AM
Complexus's Avatar
Complexus
Any suggestion where to start?
Old Jul 31, 2013 | 01:08 PM
BDSL's Avatar
BDSL
Check for harness close to the engine. Engine gets hot, melts the wire sleeving.
Old Jul 31, 2013 | 02:42 PM
Complexus's Avatar
Complexus
I found the wire sleeve that is connected to the engine block. And it does look frayed. How do I switch it out now? If you would provide me with an email or number I can text a pic to you. I think it would help out much easier. Thanks.
Old Jul 31, 2013 | 04:02 PM
Complexus's Avatar
Complexus
Disregard that last message. I didn't spot the problem yet.
Old Jul 31, 2013 | 09:54 PM
mitsuguy's Avatar
mitsuguy
Maintenance Moderator
EFI fuse - have you tried unplugging the fuel pump and seeing if it still pops the fuse right away? That would be my first guess...
If thats not it, need to know what year make and model so we can trace power and start unplugging potential causes that are not wiring related... we can also see if there is a short to ground
Old Aug 1, 2013 | 12:12 PM
Complexus's Avatar
Complexus
It's a 1995 Sc 400. I have noticed that when the car does start the odometers take a minute to turn after it is running.
Old Aug 2, 2013 | 03:48 PM
Complexus's Avatar
Complexus
Being that my O2 sensor was bad and that it's wires were seared off. Can this be the possibility why the EFI fuse kept blowing? Please lmk
Deegee
Aug 15, 2019 08:48 PM
JDMb16bEG6
Oct 10, 2011 10:10 AM
Parker Gen
Apr 25, 2009 07:01 PM
madmax98
Aug 11, 2008 11:14 PM
papodotcom
Aug 1, 2008 09:59 AM
