Alternator & Batteries
Old Nov 27, 2009 | 06:57 PM
GS4_Fiend's Avatar
GS4_Fiend
Post Alternator & Batteries
Should I get OEM alternator which cost $400+ or is therean alternator that you guys could recommend? It's falling below specs.
Planning to replace my battery since it's 6 years old. Which one should I get?
This one would almost be the exact one like OEM 600 CCA, and the alternator won't have any problems fully charging it.
http://www.interstatebatteries.com/c...nths+-+600+CCA
Or this is higher than OEM, 800 CCA, which the alternator would need to charge longer for it to fully charge.
http://www.interstatebatteries.com/c...nths+-+800+CCA
I do have a sound system: 4 channel @ 200 RMS and a mono @ 300 RMS.
Any help or suggestions from you guys would be greatly appreciated. Thanks!
Old Nov 28, 2009 | 12:42 PM
BDSL's Avatar
BDSL
Just take the alternator out and get a local rebuild shop to rebuild it for roughly $100.
Old Nov 29, 2009 | 06:54 PM
mitsuguy's Avatar
mitsuguy
Maintenance Moderator
batteries only drain as much as you let them...
if you let the 600 drain 25%, you still have 450 left... if you let the 800 drain 25%, you still have 600 left...
the alternator only has to charge what you use... the 800 will be better overall...
Old Nov 29, 2009 | 08:11 PM
GS4_Fiend's Avatar
GS4_Fiend
Thank you mitsuguy
Old Dec 18, 2009 | 08:17 AM
Lexs400's Avatar
Lexs400
goto auto parts warehouse website and look for the rebuild units. they're usually pretty cheap and they have warranty as well.
Old Dec 19, 2009 | 01:16 AM
Hayk's Avatar
Hayk
What does that mean? Do batteries lose charge and never get it back? I always though you could use the battery for the radio for at least an hour before you had to recharge it.
Old Dec 19, 2009 | 02:37 AM
mitsuguy's Avatar
mitsuguy
no, I mean that if you have a high capacity battery, it doesn't hurt the alternator, because the alternator only needs to recharge what you use...
Old Jan 13, 2010 | 11:40 AM
o6spdracer's Avatar
o6spdracer
GS4_Fiend, Lextreme does and has some rebuilt ones as well. He is in SoCal too.
Old Jan 13, 2010 | 03:23 PM
GS4_Fiend's Avatar
GS4_Fiend
Thanks for that
Hbhandal
Nov 30, 2015 01:52 PM
HiPSI
Apr 8, 2011 04:11 PM
ted920
Aug 2, 2006 08:43 AM
Neo
Maintenance
Nov 30, 2004 06:29 PM
