Question about maintenance for 307K SC400?
Old Apr 3, 2007 | 07:03 PM
lem321's Avatar
lem321
Question Question about maintenance for 307K SC400?
Hi all,
I'm new to this forum and had some general questions re: my 1994 SC400 that has 307,000 miles (schedule B conditions) on it. I was looking up the maintenance schedule and couldn't find anything specific on when to change the timing belt, AT fluids or differential fluids. I have been changing the belt about every 100K miles. What do you all think? Also do you usually also change all the drive belts, seals including water pump at the same time as my (non-dealer) mechanic recommends? I also use 5-30 oil as recommended by the factory with very little leakage. Any opinions on viscosity with this hi-mileage engine?
What is the most mileage people have seen with this engine? Mine is mostly freeway miles.
Thanks in advance for any advice.
Old Apr 3, 2007 | 07:31 PM
96gti2.0t's Avatar
96gti2.0t
im not sure on the schedule intervals but i love to see a sc with this many miles any pics?
Old Apr 3, 2007 | 07:36 PM
tkafam1's Avatar
tkafam1
timing belt and water pump every 90k
check out this thread for mileage https://www.clublexus.com/forums/sho...ighest+mileage
What kind of gas mileage do you get?
Old Apr 3, 2007 | 08:18 PM
lem321's Avatar
lem321
Mostly freeway (90%) gets me about 22mi/gallon.
More if I keep under the speed limit.
Old Apr 3, 2007 | 08:20 PM
lem321's Avatar
lem321
Smile
Will post when I clean it up a bit.
Thanks.
Old Apr 3, 2007 | 09:58 PM
VegasSC300's Avatar
VegasSC300
307,000 miles "that's incredable"...what a great car!
Old Apr 3, 2007 | 10:34 PM
O. L. T.'s Avatar
O. L. T.
Keeper of the light
Old Apr 3, 2007 | 10:55 PM
o2GS43o's Avatar
o2GS43o
Dang, that's a lot of miles... Since the timing belt and waterpump are in the same region, i usually replace those at the same time since it takes a lot of time to change the timing belt and water pump... I'm not to sure about the SC nor the GS, but generally this is the rule of thumb...
Old Apr 3, 2007 | 10:56 PM
o2GS43o's Avatar
o2GS43o
Originally Posted by O. L. T.
Is that on the original motor?
Old Apr 4, 2007 | 09:06 AM
narfy's Avatar
narfy
if you're changing the water pump, change the timing belt as well, as you have to remove it to get the water pump out...
100k is not too late to change your timing belt on a 1UZ if you're not leaking any oil... but at 100k, change EVERYTHING... water pump, timing belt, idler and tensioner bearings, cam and crank seals, serpentine belt, dizzy caps, rotors, plugs, wires...
Old Apr 4, 2007 | 10:56 PM
TRDRacer's Avatar
TRDRacer
OK you said the car has 307,000 miles but the mileage indicator says 621,382? Did you get a new engine in between, maybe a rebuild?
Old Apr 5, 2007 | 02:09 PM
narfy's Avatar
narfy
2 different people posted that... lem321 has 307, o.l.t. posted 621
Old Apr 6, 2007 | 09:27 AM
toy4two's Avatar
toy4two
At that milage I would drain/refill the ATF, and replace the timing belt and water pump. If you want to stop those leaks switch over to a 5W-30 for high mileage vehicles, they have additives that will swell up the seals and stop the leak in 1-3 oil changes.
Toyota sure can make a reliable car.
Old Apr 9, 2007 | 12:30 PM
ElitistK's Avatar
ElitistK
My friend's mom drives a 425k mile 4runner. She is not going to ever sell that car.
Old Jan 13, 2015 | 10:36 AM
lem321's Avatar
lem321
Default Gave up the ghost
Since I posted as the original poster, I now have 458K miles and the SC400 finally died. Probably oil from a leaky valve cover got into the plugs so one bank on the driver's side is not firing. The radiator also sprung a leak. Decided to not invest any more into the old girl. Just purchased a "new" 2000 SC400 in Millenium Silver that only has 112K miles and relatively speaking, it looks new. These are really great cars!
cfkingfish
Jul 14, 2011 11:26 AM
rcftx
Mar 31, 2009 10:22 PM
WDoherty
Jan 8, 2008 09:45 PM
marcman18
Maintenance
May 14, 2001 10:08 AM
