Help again guys! Overheating.......
Old Jan 18, 2006 | 10:01 PM
400DGRZ's Avatar
400DGRZ
Default Help again guys! Overheating.......
I noticed a bit of steam coming up from the top of my hood by the windsheild. looked at my TEMP gauge and it was HOT. I pull over, pop the hood, and find a hose is leaking what looks like coolant.
Here is a pic of the hose c/o RAristo
Old Jan 18, 2006 | 10:04 PM
400DGRZ's Avatar
400DGRZ
Here is a closeup of the bottom of the hose(crappy cell pic at night). Goes down beside the engine. It has a green stripe around the bottom of the hose at the connection. The fluid is leaking from where the hose connects to the engine. Getting it checked out tomorrow. What could be the problem?
Old Jan 19, 2006 | 05:05 AM
Tammy's Avatar
Tammy
Replace the hoses, along with any others weeping. Might be time to change the coolant. Old coolant causes breakdown of rubber hoses along with cores.
Old Jan 19, 2006 | 05:26 AM
400DGRZ's Avatar
400DGRZ
I was using the heat off and on. Not blasting it.
Old Jan 19, 2006 | 03:36 PM
VVT-i's Avatar
VVT-i
You like when you remove the intake to replaced the starter you accidently hit that heater pipe. You may disrupt the o-ring around that pipe or cracked that metal pipe.
Old Jan 20, 2006 | 12:06 PM
400DGRZ's Avatar
400DGRZ
So is it fixable without replacing anything if the o-ring is just "disrupted"? If the metal is cracked, what will need to be replaced? A piece or a whole assembly?
Old Jan 20, 2006 | 03:30 PM
VVT-i's Avatar
VVT-i
Josh, I would go with the new o-ring and the new metal pipe.
Old Jan 20, 2006 | 04:57 PM
400DGRZ's Avatar
400DGRZ
Nuum, I called and the "metal pipe" that the hose attaches to is a complete piece that attaches to the side of the intake manifold. It is $120 and needs two gaskets that are $11 each.
Does this sound correct?
Old Jan 20, 2006 | 05:45 PM
VVT-i's Avatar
VVT-i
I know one of a friend did the same thing and he removed that metal pipe and used JB welder. It's work great and he has no problem at all. I'd never said that....
Old Jan 21, 2006 | 12:25 AM
GSquicksilver's Avatar
GSquicksilver
400DGRZ
that looks like the hoses that are attached to the rear bypass joint where the coolant flows. they had to have been removed for them to get to your starter when you changed the starter. did they change the gaskets on them?
you'll have to remove the manifold again to get to this.
Old Jan 22, 2006 | 11:52 PM
400DGRZ's Avatar
400DGRZ
Yeah the gaskets were replaced.
kizzle
Dec 27, 2018 09:57 AM
wjlevan
Dec 26, 2016 06:25 PM
james1245
Mar 3, 2016 05:06 PM
SC300_704
Jul 26, 2007 02:25 PM
