pcv valve
Old Jun 20, 2004 | 07:43 PM
sc400guy's Avatar
sc400guy
Default pcv valve
Silly question i know but im trying to get my old pcv valve out to replace it. it lookes like it should just pull right out, is it supposed too? or is there a trick to it. thanks for your help.
Old Jun 20, 2004 | 08:40 PM
DaizenLex's Avatar
DaizenLex
pulls right out , just first pull out the plastic piece which holds it in, DO NOT BREAK IT , then pull out the pcv valve from the hose
Old Jun 20, 2004 | 09:48 PM
RacingLexusBoi's Avatar
RacingLexusBoi
yes just remove the hose that is attached to it first and it should come right out.
Old Jun 20, 2004 | 10:22 PM
96sc3's Avatar
96sc3
just out of curiosity? what does the pcv valve do?
Old Jun 20, 2004 | 10:57 PM
97SC300's Avatar
97SC300
pcv valve = postivie crankcase ventation valve, basically its a valve hooked up to your vaccum lines, and the other end is in the valve cover so it sucks the oil gases out of the motor to burn them off so their less contaminants in your engine.
Old Jun 20, 2004 | 11:45 PM
DaizenLex's Avatar
DaizenLex
stated like a true lexus owner
Old Jun 22, 2004 | 08:31 PM
sc400guy's Avatar
sc400guy
hey guys thanks for the input i think its stuck i really pulled on it ill try again later thanks.
Old Jun 23, 2004 | 12:00 AM
97SC300's Avatar
97SC300
try spraying some silicone lube on it and jiggle it side to side while pulling up on it.
Old Jun 23, 2004 | 03:48 AM
mburnickas's Avatar
mburnickas
97SC300--BINGO! That is what I do and works the best, I feel.
Old Jun 29, 2008 | 07:48 AM
IS_Sunny's Avatar
IS_Sunny
How the heck do I get the new PCV installed? It was tough to get out, but seemingly impossible to get the new piece in.
Old Jun 29, 2008 | 01:28 PM
RTIS250's Avatar
RTIS250
Yes. I drove the LFA.
CL Folding 500,000
Just lube up the new one and it should push in. Sometime the rubber grommet gets brittle, and needs to be replaced.
And the PCV is not there to keep contaminates out of the oil, its there to reduce emissions. In the old days, the crankcase was vented to atmosphere, meaning all those emissions went right out to the air. Now, the blowby is directed through the PCV valve to be reburned in the engine. As a byproduct, it helps with contaminates in the engine oil.
Old Jun 29, 2008 | 08:18 PM
mitsuguy's Avatar
mitsuguy
Maintenance Moderator
if you didn't care about the environment, or the law, ideally you would just replace and put a breather on there instead of PCV - the pcv valve venting back into the intake is realistically what causes carbon deposits and such...
Old Jun 29, 2008 | 10:53 PM
RTIS250's Avatar
RTIS250
CL Folding 500,000
Yep.. my old 600hp camaro had valve cover breathers
Old Jul 6, 2008 | 01:36 AM
labrealiv's Avatar
labrealiv
And still pass smog test? Or are the 2 unrelated?
Old Jul 6, 2008 | 05:42 AM
mitsuguy's Avatar
mitsuguy
a missing / removed pcv valve will cause a failure of the visual part of the smog test, however it will not set a check engine light (so long as the tube is closed off), and it will not cause higher emissions at the tailpipe...
Returd
Jun 2, 2023 07:47 AM
flux702
Apr 29, 2020 08:08 PM
decypher
Aug 22, 2011 09:30 PM
