1UZ valve clearance - where do I get the tool?
Old May 12, 2017 | 01:16 PM
Returd's Avatar
Returd
Default 1UZ valve clearance - where do I get the tool?
I found this guide for setting valve clearance
http://www.lextreme.com/valve_clearance.html
in the 4th frame down there is a tool for depressing the valve for shim removal. Where do i get one of these?
Old May 13, 2017 | 06:48 AM
Returd's Avatar
Returd
ordered one from Amazon
Schley Products- Inc SCH88250 Valve Adjusting Tools Toyota-Lexus
Old Apr 25, 2023 | 12:53 PM
LWechsler's Avatar
LWechsler
10th Gear
Unless Your Lexus has over 150,000 miles I would not mess with the valve clearance. Besides I believe its made of Hydraulic lifters that do not need adjustment, check your manual !
Old May 14, 2023 | 09:52 AM
Ali SC3's Avatar
Ali SC3
CL Folding 100,000
I haven't actually seen one of those outside of the manual, I've always measured and if any are out of spec or way off (rare) then pull cams, measure shims, swap/ make adjustments, reinstall and check gaps again. Rarely do they need any adjustments unless they've been mixed up at some point, in that case you can usually figure out where they're supposed to go from one round of measuring and swapping around and don't mix up your buckets keep them in the same place. So measure first and the most likely scenario is they don't need to be re shimmed.
The more handy tool is the toyo tool for compressing the valve springs, as it's a good idea to do valve stem seals when your doing head work. Eventually they'll start smoking so it's good to do it once when it's easy.
Old May 23, 2023 | 10:43 AM
Klapped96's Avatar
Klapped96
I know this thread old and probably resolved but here. This is where you'd get factory special service tools. I mean its definitely dealer money that people like me cant even touch upon. but is something.
https://toyota.service-solutions.com...ages/home.aspx
Old May 24, 2023 | 12:08 PM
Tallyhoe's Avatar
Tallyhoe
Thanks for this one... Maybe useful for later use.
Old Jun 2, 2023 | 05:46 AM
Klapped96's Avatar
Klapped96
Me again. somehow stumbled onto lexus' special service tools. its probably all the same but for giggles here.
https://lexus.service-solutions.com/...ages/home.aspx
Old Jun 2, 2023 | 06:23 AM
Gerf's Avatar
Gerf
There are lots of places to get these tools, just google the part numbers.
Old Jun 2, 2023 | 07:47 AM
Klapped96's Avatar
Klapped96
Smile
Sure, I'm just posting resources. Just went down the rabbit hole on ProDemand and found myself staring at spec tools for Lexus. but if I'm posting in the wrong hood, someone let me know?
monet33
Jun 23, 2015 03:15 PM
Lexmex
RX - 1st Gen (1999-2003)
12
Feb 10, 2006 09:51 AM
