LX - 3rd Gen (2008-2021) Posts related to the LX570 belong in this forum
AHC(help)
Old Feb 22, 2020 | 01:10 AM
ahmedd's Avatar
ahmedd
Default AHC(help)
i have a lx570 with ahc
i just wanted to know how do i keep my car on high or low with it going back up, basically removing the speed limit on ahc.
Old Feb 22, 2020 | 05:57 AM
Active Streak: 30 Days
Is this a new LX or an older LX? I am assuming the height control is failing?
Old Feb 22, 2020 | 12:26 PM
Ratchey's Avatar
Ratchey
You can't unless you pay someone a lot of money to crack and reprogram the software.
Old Feb 23, 2020 | 09:09 PM
scc1515's Avatar
scc1515
Like others have said, you would need to somehow reprogram the software. However, you can adjust the sensors and gain a bit of lift out of it.
Old Feb 26, 2020 | 11:24 AM
UCrazyKid's Avatar
UCrazyKid
You cannot do what you are asking. There is good reason for this. Alignment changes with the various heights, as well as suspension travel limits and vehicle stability. There is a ton of information on AHC over in the Land Cruiser 200/LX570 forums on www.ih8mud.com. It is a very sophisticated and specialized system that is very often underrated.
https://forum.ih8mud.com/threads/can-lx570-lc200-ahc-ride-be-tuned.1171807/
https://forum.ih8mud.com/threads/lx570-ahc-basics.1053154/
https://forum.ih8mud.com/threads/ahc...#post-12565137
Old Feb 26, 2020 | 01:51 PM
DarKnight's Avatar
DarKnight
I was sitting my truck today eating lunch with it at the highest setting and after about 30 minutes the front end went down to normal height by itself. Kind of caught me off guard because it lowers so much faster than it raises.
Old Feb 26, 2020 | 04:05 PM
hankinid's Avatar
hankinid
Gravity...
Old Feb 26, 2020 | 07:14 PM
z32's Avatar
z32
Must the lunch that started to be digested in your body .
I am assuming you had your engine running while parked. The level sensor could be at a bother line (front vs. rear height with respect to the road / ground), and a slight movement was enough to cause the front / rear leveler adjustment. It's also not good to allow your engine to idle unnecessary.
Old Feb 27, 2020 | 05:00 AM
DarKnight's Avatar
DarKnight
How am I supposed to watch movies during my lunch break?
Aug 30, 2019 06:50 AM
Scooter24
Dec 27, 2005 09:17 AM
LexFather
Aug 27, 2005 04:18 PM
