LX - 3rd Gen (2008-2021) Posts related to the LX570 belong in this forum
Transmission Drain and Refill
Old Sep 12, 2024 | 07:23 AM
vgg659's Avatar
vgg659
Default Transmission Drain and Refill
I understand the concept of an overflow tube, but given that I have no reason to think that my current fluid level is wrong, why couldn't I replace new fluid by volume of old fluid removed, with both being the same garage temperature? I will be using OEM fluid.
I ask because I plan on doing multiple drain and refills about a week or so apart. I've owned my LX for the past 50K miles, and not one drop of any fluid of any sort is leaking (thank you Toyota/Lexus). The procedure for using the overflow tube seems much more onerous than necessary, again given my fluid levels are undoubtably correct.
Can the overflow tube approach be done on the final drain and refill without much risk? Seems to me the answer is yes. Am I missing something?
Old Sep 12, 2024 | 09:27 AM
Misteracng's Avatar
Misteracng
Replacing fluid by volume is an acceptable technique if you are sure that the fluid level is correct to begin with. I chose to do the drain and fill using the temp check overflow method because I already had an OBD reader for the trans temp. If you plan to do multiple drain and fill, you might as well do it all at once. Drain and fill, then start the car and run through the gears a few times and then drain and fill again until you are satisfied. The reason is, the most amount of work for this job is taking apart all the covers and particularly the cover over the fill port. In this way, you can just put in the same amount of fluid until the final check and just use the overflow tube once. If using the temp check method you dont even have to measure the fluid for a drain and fill. Just drain the fluid, resinert the overflow tube, fill until fluid comes out, insert plug and run through the gears, then drain and fill again. Temp check after the last drain and fill.
Old Sep 12, 2024 | 09:32 AM
Oro's Avatar
Oro
I am unclear how you know your fluid level is correct, if you have not checked it? It is not uncommon to find the factory fill off, or prior service get it off. I opened an a760H recently that had been shop serviced 25k miles prior, and it was a quart low. Others have reported the same on the initial service post-factory. Your LX from the Tahara plant would hopefully have had better quality control and had a 2nd quality check.
It is not unreasonable to assume it’s close, though, and do as your suggested - replace the volume, then do a final check after the 2nd one. Or your could verify the fill level on the 1st, then do the volumetric swap the 2nd time. The temperature does not have to be a tremendous hassle. Five minutes of slow driving on a typical transmission will raise it to 100 to 110F, starting from 60 to 70F (I’ve tested this on my own SUV). It cools VERY slowly once heated, so you could do just do it that way. The thermal expansion rate of ATF is quite small in fact; shifting through the gears to get the valve body filled before the check is in fact more important. IME that can account for a 1/2 quart error (underfill) right there.
Old Oct 7, 2024 | 10:44 AM
ragabnh's Avatar
ragabnh
I wonder if anyone has replaced the transmission oil at the dealership?
What is your model year? and what was the cost?
Old Oct 7, 2024 | 12:28 PM
Misteracng's Avatar
Misteracng
I have seen people go to dealer for it, but really I think it’s really not the best option. There is of course a drain and fill procedure in the Toyota manual but the first thing I hear is that the dealership will say it’s lifetime fill and not needed to be done. Then you argue and request the price and it will be outrageous for sure, 500 dollars? Something like that. You are really best to find another shop that works on Toyotas and have them do it, at least they will probably want to do it because most mechanics actually recommend some kind of transmission service as maintenance. I did it at home with jack stands and drowned and filled twice probably took 2 hours. A shop could be done in a hour really. That’s just my thought
Old Oct 9, 2024 | 09:08 AM
Bgw70's Avatar
Bgw70
Veteran: Air Force
I did it this way on my 2007 SC430, do you think i could do it the same way on the LX570?
https://www.clublexus.com/forums/sc4...l#post11607286
Old Oct 9, 2024 | 10:07 AM
Misteracng's Avatar
Misteracng
yes you can do the complete drain that way, many people have done it. I guess maybe the location of the lines to use might be slightly different but there are write ups. There is some thought that swapping all the fluid out is not recommended, but it’s not universal consensus.
Old Oct 22, 2024 | 08:22 PM
mfeferman's Avatar
mfeferman
I did it this way on my 2015 LX. I had planned to track the amount I pulled out versus put back in, but ended up spilling a bunch and lost track of in versus out (I had to buy several more quarts to cover my spill-loss). In the end, I used the overflow tube approach, since I have both TechSteam and an OBDII reader, but it still felt like a haphazard approach. Now I need to do the AHC globes and fluid, but I'll probably wait until at least one of the globes goes bad.
2015 LX w/119k
Old Oct 24, 2024 | 10:23 AM
biff44's Avatar
biff44
this is what i heard last time i asked. they gave some b.s. on having to heat up the fluid, etc.....
its a shame there is no transmission dip stick, as i would just vacuum it out.
Old Oct 24, 2024 | 10:30 AM
Misteracng's Avatar
Misteracng
The warming procedure is correct, although most just remove a certain amount and put back the same, that is fine as long as you for sure know the previously level was correct. Otherwise you must refill and warm tranny to the recommended temp range and open the overflow plug to set the level. Dipstick would have been easier cause you could theoretically extract from the dipstick if overfilled. This method with the overflow works fine in that it sets the level and drains at the same time.
I would only go to the dealer for warranty items or recalls where you are not paying for anything. Otherwise any normal maintenance or repair you are paying for you are much better off finding a mechanic you like or do it yourself.
Old Oct 27, 2024 | 05:10 AM
biff44's Avatar
biff44
So my naive question, on the LX570, the refill plug is up high on the side of the transmission. Can i assume that when the transmission is warmed up, the fluid level should be right at the bottom of the fill hole? i.e. if i open the fill hole, excess will run out until the level is perfect?
Old Oct 27, 2024 | 08:03 AM
Misteracng's Avatar
Misteracng
No this is not correct, the fill plug on Toyota trucks is higher up but is only used for filling. If you have the older lx570 I think with the 6 speed then there is is separate overflow plug on the bottom of the transmission, this is the one you when the temp is reached to set the level, on the 8 speed like mine, the overflow is in the same hole as the drain plug, you just remove the drain plug then the overflow pipe to set the level, these levels are all just maybe a couple of inches from the bottom of the pan, so the level of the fill plug is much higher.
Chris03218
Jun 16, 2025 04:01 AM
unebonnevi
Hybrid Technology
Nov 21, 2022 01:20 PM
1Cleanbird
39
Jan 22, 2020 01:05 PM
350rx
Oct 30, 2019 08:04 PM
ISFer
IS F (2008-2014)
14
Apr 27, 2010 11:56 AM
