LX - 3rd Gen (2008-2021) Posts related to the LX570 belong in this forum
LX 2017: Rear Climate Sync Issue
Old Oct 23, 2024 | 04:07 PM
TTLongIs's Avatar
TTLongIs
Default LX 2017: Rear Climate Sync Issue
Hi All… apologies if this has been covered but didn’t see anything with a quick search.
When I have someone in the rear seat the “Auto” works and recognizes them and sets temp to match the Front.
Problem. If Front is set to 68 and back is set to same. The 68 temp in back will it will turn seat heat and heat on vs. AC (which would match front)
Is there a rear thermostat that maybe that went bad?
thanks for the help / ideas…
Old Oct 29, 2024 | 02:35 PM
baktasht's Avatar
baktasht
Follow the process in this video to retrieve any error codes, then reset the codes, and then drive for a while and check again to see if any codes come back.
Sometimes you will find that weird AC issues just clear up after you do the reset:
Old Oct 29, 2024 | 02:57 PM
TTLongIs's Avatar
TTLongIs
Thank you I’ll try that!
Old Oct 29, 2024 | 03:23 PM
TTLongIs's Avatar
TTLongIs
I was able to get codes:
19… rear room temperature sensor
Looks like pretty basic part to switch out. Can anyone point me to where the sensor is located?
Old Oct 29, 2024 | 03:46 PM
baktasht's Avatar
baktasht
Before you try to swap the sensor, do the reset and drive for a day or two to see if the error comes back or if it starts working again. Sometimes a reset fixes the weirdest toyota/lexus HVAC issues.
Old Oct 29, 2024 | 03:50 PM
TTLongIs's Avatar
TTLongIs
Will do. Thanks for the help!
Mbbarron
Jan 23, 2020 08:57 PM
DerrickM
Nov 18, 2018 05:46 PM
LexusVet
GX - 2nd Gen (2010-2023)
Jan 28, 2013 12:58 AM
cossie1600
RX - 3rd Gen (2010-2015)
Dec 22, 2012 09:12 AM
thegx470
GX - 1st Gen (2003-2009)
Feb 24, 2003 05:40 PM
